Old 07-21-2006, 12:14 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
New Thermocouple not the answer
I just changed the thermocoupler in my Dometic fridge because the pilot doesn't stay lit. It still doesn't stay lit. Could it be because I had my main gas tanks changed over to the new valves? I'm lending the trailer out today & they won't have any electric, so I thought it would be nice to use the gas. It worked before I changed over the tanks. Any suggestions for me to try before they take off? Thanks,
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 07-21-2006, 12:27 PM   #2
Becky.
The thermocouple must be tightened very securely, like "TIGHT".
Also, it "must" be in the flame, not just close to it.
If that doesn't do it, then you could have several problems.
1. The LPG pressure is to low.
2. The flame is too low.
3. The Reefer gas valve itself, is bad.
Old 07-21-2006, 12:29 PM   #3
You may have got some air in the system when you changed the tank valves. I usually light a burner on the hob to clear any air in the system, before attempting to light the water heater or fridge pilot lights. Try the hob burner trick, and get the water heater pilot going, before making several tries with the fridge. It may take some time to clear the air.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 07-21-2006, 12:44 PM   #4
Becky B.'s Avatar
1964 17' Bambi II
Thanks Andy. I just ran out and cranked down on the thermocoupler "tight" and it now stays lit. I've always been taught not to overtighten, but here it doesn't apply! The happy campers can now take off to the Oshkosh Airshow and have some cold beers!
Becky
1964 Bambi II
1988 Avion 32S
Airstream keys Pahaska Our Community 15 06-16-2005 09:03 PM
Is Thor/AS pricing themselves out of the TT business? John Our Community 52 12-19-2002 01:02 PM
Vista View Windows On 1979 31' Soverign montanaandy Windows & Screens 14 10-17-2002 05:03 PM
Wheel Assembly Balancing CJsTs Wheels, Hubs & Bearings 41 09-11-2002 07:55 PM
Ammeter smily Electrical - Systems, Generators, Batteries & Solar 14 08-12-2002 09:09 PM
