Old 02-08-2006, 07:07 PM   #1
sequoiacoast's Avatar
1968 24' Tradewind
Eureka , California
New Dometic or Not??
I am currently in the process of gutting my '68 Tradewind and the refer is the item on its way out. I have not tried it to see if it works, or how well. But since I am removing it and it is not fun I'm considering replacement, as not to do it again... at least for a loooong time.
So, I am thining about a RM 2554 3-way from I don't know yet - got the #s from Dometic.com. Is 3-way what I need?
I'm torn because of the price, but to have new sure seems reassuring. Anyone have convictions????
Thanks!!!
sequoiacoast is offline   Reply With Quote
Old 02-08-2006, 07:15 PM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
Not a three-way
I do not think a three way would be cost efficient in a trailer - you would need a really big wire from the alternator all of the way to the reefer in order to get enough voltage to the heat element to do any good (I think the sensor needs 13.6 volts to switch to the 12 volt boiler heater in the fridge). Lots of voltage losses come with the big amperage draw.
During the relatively short periods the trailer will actually be in tow behind the vehicle, a small bag of ice would probably keep things cool.
Any time the trailer is not being towed the 120 volt boiler heater or gas operation is an option.
I'd vote for the two-way.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 02-08-2006, 07:19 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Thanks!!!
I just had this discussion with a friend who bought a used SOB last year. He said he had never used the refrigerator and didn't even know if it worked. He said that he thought it was a 110v/LPG 2 way unit. We discussed the relative merits of the 2 way vs. the 3 way. I have heard that in the 12v. mode, the unit really eats up the battery energy. I could only see one reason for the 12 volt and that would be while on the highway and not wanting to run the LPG. You need a high performance alternator in my opinion and I wouldn't think about anything less than a 175 amp unit. I have had two of the 2 way units and have been happy with the way they worked so maybe my opinions are misplaced.
How about you 3 way owners, pros/cons and is it worth the extra $$$.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-08-2006, 07:33 PM   #4
Cedars's Avatar
1983 31' Excella
Waterloo , Iowa
Our unit came with the original (1983) three way Dometic. After checking with our RV tech, he said, Why would you WANT to run on DC? It only holds the temp, it won't actually cool food. That's all I know, and it was told to me! Now, having said all the above, I must admit at first we ran our fridge on DC a lot while under way! Also forgot to swith it a time or two, and did not have any extraordinary drain on the batteries!
Elizabeth in Iowa
The carpeting is gone! The carpeting is gone! Long live the cork floor!
Cedars is offline   Reply With Quote
Old 02-08-2006, 07:37 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
Sequoia,
The 3 way was originally produced so you could keep the refer going when you stopped to fill up a Moho......you have to shut the propane off when gassing up and the refer would then have no power. They ARE very picky about the input 12VDC as a 3-way AS 87 said. The extra cost IMHO does not justify the DC operational option. Go with a 2-way. Plus, it's way simpler to fix if it goes down.
Old 02-08-2006, 11:35 PM   #6
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Fridge Choice
Sequoiacoast, The 2 Way Seems The Better Choice Imho. How Does It Measure Up To The 3 Way In Cost? I Would Think That Would Help Make The Decision For You As The Dc Mode Would Not Be Of Very Good Use To You For Boondocking Unless Done With A Generator To Restore Battery Charge. Are You Going To Scrap The Old Fridge? If So Pm Me As I Need Some Parts To Restore Mine. Ed
BIGED52 is offline   Reply With Quote
Old 02-09-2006, 06:35 AM   #7
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
We have a three way and we generally only use it on DC only for the first day out. After that the fridge is cold enough, most of the time too cold, to last the day before we get hooked back to shore power. Keep in mind that we also use the fridge all day by opening the door for drinks or food as we drive and it still stays cold.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 02-09-2006, 07:43 AM   #8
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Thanks!!!
Oddly enough I was in a very similar situation last fall. I have a '68 Trade Wind in which the original fridge had been replaced with an electric. Since I am a boondocker that wasnt going to fly. I went ahead and bought a new fridge and put it in. I can get the details about that unit if you want.
As to your situation, here is what I suggest. First, check and see if the thing works. It may be fine and if it is why spend a grand on another one? Second, my experience was that changing out the fridge wasnt that big of a deal so having to replace your current on in another year or so wouldnt be the end of the world.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-09-2006, 08:08 AM   #9
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
see if it works
I agree with the general, give the old one a chance unless you just have a burning desire to have a brand new one. The service manuals describe how the things work, how to clean and inspect the various elements, and how to change them out if faulty. I re-habbed mine according to those instructions and it now works fine on both electric and gas, cost $16 for one small part.You can add a different front panel, on the door, if you want a more modern look. You will then have about $970 left for all your other goodies! Just an idea- tim
tphan is offline   Reply With Quote
Old 02-09-2006, 08:08 AM   #10
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
We have an apartment style 120 vac unit in ours. Most of the time we are hooked to electric at home or campsite. If boondocking the Honda generator provides power for the fridge.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-09-2006, 03:44 PM   #11
I have a 3-way Dometic, and by coincidence I used it on 12 volt today as I knew I would be re-fuelling near the beginning of the road trip, and wished to avoid turning the fridge off and on when using propane. The charging system in my truck is not sufficient to maintain the trailer batteries when the refer is on 12 volt, and I would need to fit thicker wiring, and perhaps a higher capacity alternator to do this. I don't believe the 12 v facility is worth the extra complexity and expense. If my 3-way fails, I will probably replace it with a 2-way.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 02-09-2006, 09:17 PM   #12
1968 24' Tradewind
Eureka , California
Thank you all!
I did get the fridge out today, at least into the center of the floor. The back of it looks a little scary. Major rust in places. The "flu" - thing is corroded and missing part of it. I would love to save the money, but after wrestling this one out and intending to put everything back for "good", I wonder if I shouldn't bite the bullet now? If the new unit is a little bigger I would have to re-do the cabinet.
So 2-way is fine. Good news. What does "manual" mean. I found one for 450.00 5 cu/ft. RMR2501.
Gen, What DID you put in, and where'd you find it... etc.??
If mine works... and I decide to scrap it... how should I "give it away"? I could part it, but easier to get rid of it entirely?
Old 02-10-2006, 12:33 AM   #13
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Refridgerator
Thank you all!
Dan, It may be very hard to give it away or sell it whole as shipping would be outrageous. You might give it away or sell it complete to someone who lives close to you and could pick it up. I only suggested parting it out as you stated you were in the process of getting rid of it. Also I need interior parts and a front door that you would just be discarding otherwise. I would be willing to pay the shipping on them if you make up your mind to part it out. If so and you need to sell parts I can let you know what ones I want and you can tell me if you have those parts, in good condition, and what you may want to sell them for. That's why I wanted to know....your decision. Ed
Old 02-10-2006, 06:54 AM   #14
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
...... What does "manual" mean. I found one for 450.00 5 cu/ft. RMR2501.....
This is my question as well, where can you find these manuals? I would like to rehab the 1973 era Dometic in our trailer.
www.nesa.org
Air No. 6427
Charging old Dometic Reefer smily Refrigerators 9 09-18-2017 02:50 PM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 08:07 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
Source of "Vintage" Dometic refer parts? 74Tradewind Refrigerators 3 08-16-2002 08:42 AM
Dometic Furnance Help chrisg Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-07-2002 09:34 PM
