Old 09-01-2013, 08:58 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
New convection assist fans
Made this bracket, mounted fans, fused and running...
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-01-2013, 09:02 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
These fans are most efficient when pulling rather than pushing the air. The optimal place for the fans is at or on the fridge vent outlet; either at the roof vent or directly on the side vent. This way you are assured of pulling the heated air across the condenser and out of the vent without any possibility of it getting trapped due to inefficient plenum design.
Nice install, though.........
Old 09-01-2013, 09:05 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Thanks, Lewster! If this proves to improve cooling, I will move them as you suggest... This is just "proof of concept"...
Channing
WBCCI# 30676
Old 09-10-2013, 04:52 PM   #4
dznf0g's Avatar
Oswego , Illinois
I just moved mine. We've been in the 90s this week (upper today) and I noticed a lot of turbulence (verified with cigar smoke) with the fans down low, pointed up. I had an actual downdraft at both sides of the compartment. I immediately thought of CO being pushed back down from chimney top. Not good.
Made an aluminum bracket similar to CWF and mounted below the roof vent. I used two 4" muffin fans, which each move 75 cubic feet per minute, but I am sure the vent cover restricts that somewhat. Now have a nice pull throughout the cabinet. Will monitor any performance difference.
Sorry, no pics.....too darned hot to play around.
-Rich-
Old 09-10-2013, 05:06 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Cool! Literally!
I did not have the smoky issue. However, am concerned about CO as well... Was it tough pulling roof vent or did you use another method?
Channing
WBCCI# 30676
Old 09-10-2013, 05:40 PM   #6
dznf0g's Avatar
Oswego , Illinois
Channing, as much as I hated to, I pulled the refer. four hour job, start to finish, including fabricating the mounting bracket. I mounted the fans to the aluminum using rubber faced washers and mounted rubber grommets between the bracket and ceiling. Pretty darned quiet. While I was in there, I re-taped some joints and checked my previous bubble foil insulation job.
-Rich-
Old 09-10-2013, 08:07 PM   #7
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
All fan installers:
I am curious. How much of an improvement in fridge temperature did you get after you installed your fans?
I am planning on installing three 120 more fans (45 cfm/fan) at the vent entrance which is located in the belly pan. This location is the easiest for me to access.
Dan
TouringDan is online now   Reply With Quote
Old 09-10-2013, 08:18 PM   #8
KYAirstream's Avatar
Northeastern , Kentucky
You mentioned at the roof or directly on the side vent. Are you referring to the access door in the side of the trailer that allows the inflow of air? This of course would be a lot easier to access than the roof vent.
KYAirstream is offline   Reply With Quote
Old 09-10-2013, 08:31 PM   #9
dznf0g's Avatar
Oswego , Illinois
If I may be so bold to answer for Lewster......I think he's talking about the units with both the inlet and outlet on the side of the trailer...not the top. So he's saying mount the fans on the hot air exit.
-Rich-
Old 09-10-2013, 08:49 PM   #10
You're probably right.
Old 09-10-2013, 10:13 PM   #11
kmaggard's Avatar
1994 21' Sovereign
Paradise Valley , Arizona
How are you wiring the fans? Are they on a switch? Wired to the fridge? When do they run? Battery drain?
WBCCI# 2520
AIR# 77458
Ken and Ben the Saint
Paradise Valley, Arizona
kmaggard is offline   Reply With Quote
Old 09-10-2013, 10:40 PM   #12
dznf0g's Avatar
Oswego , Illinois
I wired both fans in parallel with a pair of wires running down to the access panel area. I run a manual switch and a thermal switch ( mounted in the chimney), both in the positive line. The power and ground are in the "H block" where the 12Volt feed is for the fridge.
-Rich-
Old 09-10-2013, 10:46 PM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Please be kind and FUSE your power positive wire.
Channing
WBCCI# 30676
Old 09-10-2013, 10:50 PM   #14
dznf0g's Avatar
Oswego , Illinois
I've read that many times....but, the H-block is already fused. Any short will pop the self-resetting breaker on the refer circuit.
-Rich-
