Old 09-11-2013, 12:30 AM   #15
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by dznf0g View Post
If I may be so bold to answer for Lewster......I think he's talking about the units with both the inlet and outlet on the side of the trailer...not the top. So he's saying mount the fans on the hot air exit.
Right !.......sort of.......... I always place these fans directly on the highest vent opening which is the hot air exhaust, whether that is on the upper side wall or under the fridge roof vent.
Old 09-11-2013, 12:42 AM   #16
Mexray's Avatar
1978 28' Ambassador
Morada , California
Get one of these kits...I got one & it works great...!
Snyders RV Refrigeration - Home
Ray & Pat; Morada, CA
Old 09-11-2013, 06:40 AM   #17
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Thumbs up
Originally Posted by TouringDan View Post
All fan installers:
I am curious. How much of an improvement in fridge temperature did you get after you installed your fans?
I am planning on installing three 120 more fans (45 cfm/fan) at the vent entrance which is located in the belly pan. This location is the easiest for me to access.
Dan
Dan,
Our 63 Safari had a floor vent also, one computer fan mounted inside on the screen made a 5-10* difference on hot days. It's really surprising how much cooler the air is under the trailer.
PFC
but Iím the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-11-2013, 07:44 AM   #18
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I have one of the Snyder's kits and it does work well. It consists of a PVC gutter which spans the cooling fins with a muffin fan mounted below it blowing up. It is thermally switched and fused. It is effective and has lowered my fridge temps considerably. On the highest cooling setting the fridge compartment has had temps as low as 29f this summer. That said, I am concerned that if the fan fails, all airflow will be blocked over the cooling fins. Because of this concern, I am going to remove it and place a larger fan just under the roof vent.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 09-11-2013, 09:58 AM   #19
lewster's Avatar
Good idea!
I stopped using Stu's kits due to the small size of the fan and it's limited airflow, and for the exact reason that you brought up. I also do a lot of larger RV fridges that require significantly more airflow that the kit provides....hence the multiple fan installations.
