Old 05-13-2006, 08:07 AM   #1
need to remove frig from '73
This model 29' Airstream has mid-bath, bedroom in rear. Have removed all screws from sides and front of Dometic frig and it won't budge. What's the secret, Guys? Appreciate any help you can give me.
rhodyrunwv is offline   Reply With Quote
Old 05-13-2006, 08:24 AM   #2
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Open rear access door and see if it is screwed down to the floor. Mine was. Also, it is a tight fit and comes out hard.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 05-13-2006, 08:37 AM   #3
Darol Ingalls's Avatar
There are bolts(usually 4) through the angle iron frame around the bottom of the unit that go through the plywood floor and probably through one of the frame cross-members. Look at the underbelly skin just below the fridge. There should be four small square "patches" rivited on that cover the heads of the bolts. Open the outside access door to find the nuts. On trailers this age, these are usually rusted. Put some penatrating oil on the threads and let soak for a day or two. Meantime, find some long-handled wrenches to reach all the nuts and another set of hands to operate the wrench under the trailer. Be prepared for skinned knuckles and some frustration, but remember Airstream's original intent was to keep the fridge from moving around when traveling - not to make it easy for you! Darol
Darol Ingalls is offline   Reply With Quote
Old 05-13-2006, 09:25 PM   #4
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
You need to remove the wall (partition) to the right of the fridge. This will probably involve removing the end table next to it. Once it is removed, you'll find a 4-5" piece of right angle aluminum screwed to the floor and to the right side of the fridge. (You can't get to it without removing the wall.)
I've removed one from a '72 Overlander and a '73 Sovereign and that is all that holds it (there's also one attached to the exterior wall....forgot about that one....just remembered...it's been a while)
Unless someone else has replaced it, there aren't any other bolts in the floor, frame crossmembers, etc.
It's kind of a pain but you can't fight it. Like most A/S stuff, you have to remove at least 3 items to get to the thing you want. Here's a pic with the wall and fridge removed.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
frig and a/c suggestions Neenm General Appliance Topics 6 04-08-2007 07:42 PM
Pilot light in Frig niftypkg Refrigerators 9 04-10-2005 12:04 PM
How to remove the glass from windows? Andy R Windows & Screens 2 06-19-2002 09:30 AM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
Rust on Frig. niftypkg Refrigerators 0 05-20-2002 06:43 PM
