Old 03-12-2011, 03:58 PM   #1
1978 23' Safari
fair oaks , California
Need to convert 24V DC to 12V DC for fridge igniter
I am installing a new dometic rm2510 in my 78 safari. The fridge requires 12v dc in order to run the auto-igniter for gas operation. I was just getting ready to hook up the Airstreams pre-wired red/white dc wires and decided to check the voltage first. It turns out they are 24v.
What is the best way reduce or split the voltage to 12 volts for the fridge igniter?
bacevedo is offline   Reply With Quote
Old 03-12-2011, 03:59 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Your batteries are probably hooked up incorrectly. There is nothing that I know of in an Airstream which requires 24V.
Bill
Just my personal opinion
Old 03-12-2011, 04:04 PM   #3
au_ee's Avatar
2007 31' Classic
Pulaski , Tennessee
You should get your manual out and make sure the trailer is supposed to be wired as 24V instead of 12V. I've had RVs since the 70's and have never seen a 24V setup. It is possible that whoever connected the batteries put them in series instead of parallel (assuming they are 12v batteries).
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
au_ee is offline   Reply With Quote
Old 03-12-2011, 04:46 PM   #4
x
XXXX , XXXX
Yes definately something wrong no airstream was ever made to run on 24VDC.
Are you running on batteries now or on shore power. The PO may have messed with the power converter.
wasagachris is offline   Reply With Quote
Old 03-12-2011, 05:37 PM   #5
1978 23' Safari
thank for the feedback..I rechecked the voltage based responses. ID10T error and 1 too many new castles. I had the polarity reversed on my voltage meter and it was reading the
-VDC LED.
Old 03-12-2011, 06:23 PM   #6
x
XXXX , XXXX
-VDC LED.
I've made lots of ID 10 T errors myself and I don't need newcastles to do them. Glad to know somebody else speaks techie.
Old 03-12-2011, 07:34 PM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
You know, a true ID10T would never have posed the question.
Glad you're with us.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
12v
2007 25fb 12V electrical problem DonDiego Electrical - Systems, Generators, Batteries & Solar 14 09-12-2017 04:17 PM
IDEA for a Refrigerator install with a 12v & solar fan BB 55 Bubble Refrigerators 12 01-30-2012 11:17 AM
Want to convert from twin to full mwells4654 General Interior Topics 2 10-18-2011 06:35 AM
Dometic not working on 12V, ok Elec & Gas afordjones Refrigerators 1 08-16-2011 06:02 AM
12v Wiring @ 31' Center Bath cuyd Lights - Interior & Exterior 4 06-01-2011 05:27 PM
