06-23-2012, 11:30 PM
1971 25' Caravanner
Olathe
, Kansas
Need Refrigerator Venting Help
I need help! The previous owner removed the refrigerator from our 71 Caravannner and replaced it with a college dorm electric only one. I am replacing it with a propane fridge. The roof exhaust vent is there, but there is no air intake vent in the side of my trailer. There isn't any hole (patched or otherwise) anywhere near the fridge. Did the older Airstreams draw combustion air for the fridge from inside the trailer? I don't want to have a CO problem, but I don't want to cut the side of my trailer, either! What do you think?
Ken
"Surrender is not in our creed. Let me hear you say that..." Gunny Hiway
06-24-2012, 12:54 AM
tracker
1969 23' Safari
crescent city
Hi
I don't know if this helps or not but my 69 sarfari has a vent hole in the floor all the way through the belly pan covered over with metal hardware cloth. This allows fresh air to be drawn up into the interior. Could it be that someone made arepair to the floor that covered up this hole?
06-24-2012, 02:09 AM
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
I've redone 5 70s Airstreams and all of them had their air source through the belly pan and up through the floor.
Zep
06-24-2012, 05:59 AM
1968 24' Tradewind
Oxford,
, Mississippi
My 68 Trade Wind had a dorm fridge. I replaced it with a Dometic that was sized to fit the original opening (it is not as wide as the new ones). Don't remember the model number but PPL in Houston was much cheaper than any other place I tried to buy it. There was a floor vent for mine. Has the floor covering been replaced and the vent covered? The instructions that come with the fridge are very specific about how to properly install it so there won't be an issue with CO. They can downloaded from the Dometic web site.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
06-24-2012, 04:29 PM
1971 25' Caravanner
Olathe
, Kansas
Thanks! There is a hole that was covered in the bellypan. I assumed that it was where the gas line had passed through and had since been covered. I will open it up and use it for my air intake.
You guys are great!
Thanks again,
Ken
06-24-2012, 06:03 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Greetings Ken!
You guys are great!
Thanks again,
Ken
Something else that bears checking out as your return to an RV refrigerator in your Caravanner is the fiberglass exhaust vent housing that connects the space behind the refrigerator to the ceiling vent. These housings can crack due to age, and in some cases when a prior owner installs an AC electric refrigerator they remove the fiberglass duct. Replacement ducts are available from Inland RV and may be available from all Airstream dealers and sevice centers as I am not certain whether this is a reproduction part or a standard Airstream replacement part.
Good luck with your project!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
06-24-2012, 06:18 PM
1971 25' Caravanner
Olathe
, Kansas
Thanks Kevin,
I'll check it out!
The REAL project starts after the Air Midwest fall rally in October. We're going to gut her to get rid of that funky smell. It's either decaying plywood or rodent gifts in wet insulation. It's got to go!
Ken
06-24-2012, 10:21 PM
1973 23' Safari
1977 23' Safari
Palmer Lake
Ken, you need about 24 sq in (4x6") for the air source, not just a 1" diameter hole. There's probably a spec for this, but that's my estimate.
Zep
06-25-2012, 06:07 AM
1971 25' Caravanner
Olathe
, Kansas
Zep,
That's about the size of the patch that's down there, so I am pretty sure that's what it is. I am still working on building the cabinet for the new fridge, so I will be checking it out when I remove the old fridge and countertop.
Thanks, I don't want CO problems!
Ken
07-03-2012, 01:13 PM
1971 25' Caravanner
Olathe
, Kansas
Well you were right! The PO patched over the intake air vent under the trailer. Making a screened cover was nothing, he evidently cut the 12v wires and pulled them somewhere? Oh well I will be doing a major reno this fall so I just ran a new set under the floor. Good news is the frame I could see through the vent looked fine! Woohoo!
Now I just want to run the fridge on propane a few days in the driveway with a CO detector in there to reassure myself that it's safe.
Thanks for all the help!
Ken
