Old 12-06-2015, 05:47 AM   #1
2015 25' FB Flying Cloud
Charleston , South Carolina
Need fridge help, please
We are on the road with our (slightly) used 2015 FC 25FB. We stopped at the dealer on our way out to fix a burner that wasn't working and a small leak under the sink. I thought everything else was working. The fridge didn't seem very cold but the indicator lights were all working. Now 2 days later, clearly the fridge is not working. I do know that it had been working before we picked up our Airstream 3 months ago. I checked outside and the motor is very slightly warm.
Can anyone help? Or do you know a dealer to recommend on the I-40 west of Fairview, TN?
Bonnie
BKuhlman is offline   Reply With Quote
Old 12-06-2015, 05:53 AM   #2
Tincampers's Avatar
Sneedville , Tennessee
What indicators do you have? What setting do you have it on? Are you trying to run it on propane while you drive?
Tincampers is offline   Reply With Quote
Old 12-06-2015, 06:02 AM   #3
Indicator reads 'auto' and 'LP' but we are not plugged into electric. Running on LP only. I had it set on 'auto' and '5' for temp. It says 3 1. We are trying to run on LP while we drive.
Old 12-06-2015, 06:06 AM   #4
Tincampers's Avatar
Indicators are OK. It should be nice and cold. Is there any ice build up in the fridge or freezer?
Old 12-06-2015, 06:10 AM   #5
No ice. Things in freezer were put in frozen solid on Thursday night. I had precooled it Wed. night (I thought), but there was no frost inside when I put things in. It just felt cool. Now everything in the freezer is defrosted. Things in fridge are slightly cooler than last night, but still doesn't feel cold and there's no frost in fridge or freezer.
Old 12-06-2015, 06:14 AM   #6
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
We use a thermometer to check actual temp inside. Set it to highest cooling level and see if it cools off any. The temp control could be off.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 12-06-2015, 06:16 AM   #7
Tincampers's Avatar
He said it is set on 5 and is reading 31. I wonder if there could be an obstruction in the fridge vent.
Old 12-06-2015, 06:20 AM   #8
I don't think it's saying the temp is 31, it reads 'dot'3, 'dot'1. Dots being the indicators for auto and LP. Temp settings are 1-5. I set it at 5. I don't know if it registers in increments (e.g. 3.4).
Old 12-06-2015, 06:25 AM   #9
We are going to go get ice and put everything in coolers for now. I'll check back shortly. And I do appreciate the gracious help on a Sunday morning
Old 12-06-2015, 06:31 AM   #10
Tincampers's Avatar
The dots indicate that it is set for auto and LP. 5 is the coldest setting.
Old 12-06-2015, 06:43 AM   #11
Some Guy
djarrett's Avatar
2018 28' Tommy Bahama
Nashville , Tennessee
If Fairview, you are not far from Nashville. Camping World on Music Valley Drive (near Opryland Hotel) is open on Sunday's and an authorized dealer for Dometic.
You should be able to get them to look at it today. My guess is your gas flame went out while driving, but that is simply a guess.
D
The Jarretts
Nashville, Tennessee
2018 27' Tommy Bahama
2015 F250 TV-Petrol
WBCCI # 22342
djarrett is offline   Reply With Quote
Old 12-06-2015, 10:01 AM   #12
batman's Avatar
1964 22' Safari
modesto , California
A Dometic fix. You can try to reset the refer controls by disconnecting all power 110v and 12v (battery terminals) for 10 minutes then reconnect the power. Hope that helps.
-Dennis
batman is offline   Reply With Quote
Old 12-06-2015, 10:46 AM   #13
2012 22' FB Sport
Lake Forest , California
Good luck. Our 2015 25' flying cloud has been in the shop with frig problems no less then five times. In fact it's in there now. Come on Dometic, spring for a new one. This is killing us!
HrLola is offline   Reply With Quote
Old 12-06-2015, 10:51 AM   #14
2018 23' Flying Cloud
Eagle Creek , OR
Send a message via Skype™ to almcate
Had a similar thing happen to ours. Screen indicated power to the computer ship that runs the fridge, but didn't get a temperature read out. Like the furnace or water heater, I know that if propane runs out, you have to shut off any of the three to reset the thermostat control and shutting off the fridge and turning back on wasn't doing the trick.
Someone here suggested batman's fix (actually, you only need to put the power switch to store from use, and if on shore power, disconnect) to COMPLETELY shut power off to the fridge computer chip. Kind of like the difference between a warm reboot/restart of a computer and a full shutdown restart to clear out the cobwebs to reboot the fridge chip.
Question: better to be a successful pessimist or a failed optimist?
Al & Robin
2018 Airstream 23FB Flying Cloud
2015 F150 XLT 3.5L EcoBoost, 4WD
almcate is offline   Reply With Quote
Making a 2-way Fridge into a 3-way Fridge? Bunkroom Refrigerators 18 06-03-2014 04:37 PM
Fridge Vent and Fridge 12V DC wiring rodsterinfl Electrical - Systems, Generators, Batteries & Solar 1 05-03-2014 09:33 PM
Please help - opinion please - 1967 caravel for $1000 knishiya Airstream Trailer Forums 5 05-11-2012 09:33 PM
Need Fridge...can Solar keep up with an Electric Only Fridge??? chowman2011 Refrigerators 13 05-17-2011 08:59 PM
Small fridge to large fridge ? 4tumbleweed Refrigerators 3 07-04-2010 06:44 AM
