Old 09-06-2011, 07:13 AM   #1
asmodeus's Avatar
1995 34' Excella
FLORENCE , Texas
Need a little help on fridge wiring...
i am hoping someone could tell me the wiring for the fridge... as i purchased the trailer after the old fridge caught fire there was no telling what wire goes where... i am back to a point on the wiring that i have good wire and the color codes are good... just do not know which wire goes to what... thanks in advance... oh i have a '95 34' excella... thanks
asmodeus is offline   Reply With Quote
Old 09-06-2011, 08:12 AM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
There are only two wires involved. The white wire is ground and the colored wire is +12v. These go to the terminal block on the lower left of the fridge. The block will have two openings for wires with clamp screws. Just look on the fridge wiring diagram for which wire goes where.
If you need to extend burned-off wires, use #14 automotive hookup wire in appropriate colors.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 09-06-2011, 08:33 AM   #3
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I'm a long ways from knowledgeable about RV refer wiring, but isn't 115V AC also involved?
Ken
Old 09-06-2011, 09:07 AM   #4
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
rvmobile.com has some great schematics and wiring diagrams for fridges.
Old 09-06-2011, 10:58 AM   #5
Pahaska's Avatar
Hays County , Texas
Ken
The fridge has a regular 120v plug that goes into an outlet somewhere in the refrigerator compartment. I didn't mention that since I thought it was obvious.
John W. Irwin
WBCCI #9632
Old 09-06-2011, 11:20 AM   #6
Ag&Au's Avatar
I remember seeing that now that you mention it.
Ken
Old 09-06-2011, 06:53 PM   #7
asmodeus's Avatar
1995 34' Excella
FLORENCE , Texas
thanks for all the help and the link... yeah i got the 120 volt side under control... it is just when i got into things there were like 20 wires in a bundle and could not see what color was what... now the fun of tracing down the wires...
the first picture should be the bundle from the floor to behind the fridge.. the two blues are for sure to the thermostat for the front furnace... and the brown and white ground should go to the light above the dinette... not sure about the rest...
ID:	139539   Click image for larger version
ID:	139541   Click image for larger version
Old 09-06-2011, 07:29 PM   #8
Pahaska's Avatar
Hays County , Texas
The fridge uses very little 12v. Just about any white-color pair should give you enough 12v to run the fridge. the only 12v loads are lights, control box electronics, igniter, and gas valve. All of these are light loads. Just check that you have 12v between the pair you choose or get the color from someone else with a similar year rig.
John W. Irwin
WBCCI #9632
Old 09-06-2011, 07:38 PM   #9
asmodeus's Avatar
1995 34' Excella
FLORENCE , Texas
awesome thanks a lot... i will do... will let you know how it turns out
Old 09-07-2011, 09:24 AM   #10
1969 27' Overlander
Albuquerque , New Mexico
Here's the Installation manual for the Dometic fridges:
http://gasrefrigeration.net/dom_tech...300_2800OP.PDF
Has the wire connections, guages, requirements, etc.
I was looking for the same answers, so this is what I came across.
Hope that helps!
edglenn is offline   Reply With Quote
Old 09-07-2011, 06:56 PM   #11
asmodeus's Avatar
1995 34' Excella
FLORENCE , Texas
helps a great deal thank you very much...
fridge, wiring diagrams needed
Clipper, Dometic Refrigerator, Fridge Lamp Switch masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 10 01-05-2013 11:14 AM
1991 Excella 1000 - New Radio need wiring help! jbbaldwin Audio, Video & TV 0 07-13-2011 12:04 PM
New fridge on the Outs? skydiva Refrigerators 2 07-04-2011 03:04 PM
Fridge for my '52 Cruiser Cruising52 1950 - 1958 Cruiser 4 06-08-2011 07:11 PM
Skip the Fridge? (Overlander Newbie) pyrenees Refrigerators 15 05-09-2011 05:30 PM
