Old 06-29-2010, 07:36 AM   #1
1977 Argosy 24
Milltown , Wisconsin
Need 110V heater RM66
A friend of mine has an Argosy with a Dometic RM66 refrigerator in it. It works great on propane but not on shore power. We have traced the problem to a burned out electric heat element. Dometic says the part is obsolete. Does anyone know of a place that may have one in stock, or a good used one? The number on the element is 173713, 150 Watt 110 volt. It measures about 11/16" in diameter and 4 7/8" long. Thanks Brian
ventport is offline   Reply With Quote
Old 06-29-2010, 08:23 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
First propane works faster, cheaper and better than electricity. You just think electric is better when you aren't paying for it directly. One option is to simply say "I have a propane water heater" and forget about the electric element. I fulltime, rarely turn my water heater off, and don't go through a 30 lb. tank in six months! An electric heater will take 15 minutes to recover - on propane, 5.
Next: old water heaters - are they worth repairing? IMHO, NO. RV water heaters - simply because most are 6 to 10 gallons, get a heavy workout while camping. They will rust and get pinhole leaks - worse if that happens on the propane tubing than in the water chamber! After a while you're betting your life on two chances - will it catch your RV on fire, or will it kill you with carbon monoxide poisoning? If the water heater in the Argosy is original it's over 20 years old, probably over 30. Even if it's rarely been used, the elements have gotten to it unless it's been in climate controlled storage the whole time.
The cost of a new water heater? Compared to the cost of a melted RV?
Now if the water heater IS newer, just look for something generic at Camping world. Take your current element with you when you go looking.
Happy Trails Paula
Old 06-29-2010, 08:29 AM   #3
1977 Argosy 24
It's a refrigerator, not a water heater.
Old 07-01-2010, 05:31 AM   #4
1972 Argosy 26
Spring Creek , Pennsylvania
try Atco America (800 227 3180). They have one to fit my RM60.
internat6 is offline   Reply With Quote
Old 07-01-2010, 05:54 AM   #5
1977 Argosy 24
Thanks for the reply's we found one.
Old 07-09-2011, 01:44 PM   #6
shebeen's Avatar
1975 29' Ambassador
1995 31' Land Yacht LE
Southwest , New Hampshire
Hi Ventport....could you post where you got it. I've got the same heater part # that's burnt out.
shebeen is offline   Reply With Quote
gas "push" knob / rod broken on RM66 fridge? 2Alaska Refrigerators 2 07-19-2014 01:01 PM
Going to 110v only hockeyrink Electrical - Systems, Generators, Batteries & Solar 11 09-03-2008 09:24 AM
110V outlets cookeville34 Electrical - Systems, Generators, Batteries & Solar 2 09-17-2006 07:15 AM
110v Traveler? prairieschooner Electrical - Systems, Generators, Batteries & Solar 12 09-14-2006 09:17 AM
dometic RM66 part needed airstream4 Refrigerators 0 06-20-2006 01:29 PM
