Old 06-28-2007, 06:03 PM   #1
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Mythbusters Burp the Fridge
This week a Certified Master RV Tech (who will remain unnamed) and I decided to bust the myth about burping ammonia evaporation RV refrigerators to "fix" malfunctioning units.
I had a new one on order, so what the heck?
Under ther supervision of "Ken J", the CMRVT and I removed the malfunctioning Dometic 2620 and did the following:
  1. Put it on its side for 3 minutes
  2. Put it on its top for 3 minutes
  3. Put it on its other side for 3 minutes
  4. Put it on its top for 3 minutes
  5. Put it on side one for 3 minutes
  6. Put it upright
  7. tilted it forward at a 45 degree angle for 3 minutes
  8. Tilted it backward at a 45 degree angle for 3 minutes
The chart tells the story.
What should I do, reinstall the old unit and sell the new one, or install the new one and sell the old one?
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 06-28-2007, 06:08 PM   #2
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
We turned ours upside down for 24 hours and it started right up and got cold almost immediately. If I understand your chart correctly, it's not very consistent with it's temps. Maybe I should check our temps before hubby reinstalls it.
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 06-28-2007, 07:03 PM   #3
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
What does it all mean
Michael
ArtStream is offline   Reply With Quote
Old 06-28-2007, 07:24 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Michael
It is a method that can be used to attempt to revive an old fridge that has stopped cooling properly. From my understanding...the ammonia fridges will get an air bubble in the system from sitting and not being used. By turning the fridge up side down you get the bubble to break up or move and the fridge will start working again. It doesn't always work but does work often enough to make it worth a try.
Aaron
WBCCI #XXXX AIR #2495
Old 06-28-2007, 07:27 PM   #5
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Send the working? one to me for further long term testing.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 06-28-2007, 07:30 PM   #6
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
What Do it Mean?
The Dometic 2620 has push button controls that allow you to select cooling levels 1-5. On 6-6-07, I began recording Level, Ambient Temperature (Inside Airstream Haven), the temperature inside the Fridge, and the temperature insdie the Freezer. On 06-17-07, I installed a fan in the compartment behind the fridge. On 06-23-07, we removed the fridge and burped it.
WHereas before burping the unit could not handle ambient temperatures above 80 F, it now handles temperatures above 90 F quite well.
Ken L
1966 Tradewind 24
Old 06-28-2007, 07:50 PM   #7
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Thanks Aaron, and Kelvan for posting the test.
Hey, isn't Kelvan a measure of heat or sumpthin?
Michael
Old 06-28-2007, 11:30 PM   #8
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Good info to have. Thank you for posting this and taking the time to track it all. In the past I've used the burping technique (but a full 24 hours) to revive what would have been considered a dead refer. So far the results have always been a better functioning refer, and money saved. We've done this more than once to the same refer and it has continued to improve. The fan in back to move air through was also a great addition.
Barry
safari57 is offline   Reply With Quote
Old 06-29-2007, 12:12 AM   #9
lewster's Avatar
Naples, FL , Hood River, OR
This 'technique' seems to work....but only for an air pocket that forms from a fridge that has been sitting unused for an extended period.
If you have a blockage (even a slight one) that is caused by solidification or crystalization of the sodium chromate that is a component of the refrigerant, then all you are doing is postponing the inevitable, as crystalline blockages will not dissipate and will get worse and render the unit useless eventually.
Old 06-29-2007, 07:07 AM   #10
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Part of this process involves three six packs - we were lucky because we didn't have the three six packs and it still worked - I would suggest you don't try this at home as it takes a highly trained professional to supervise this operation - part of it wrist action and partly getting the speed and angles of the turn correct.
We sure had some fun with this
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 06-29-2007, 08:46 AM   #11
100 percent "on."
And when will that "burped" reefer quit?
When your on that trip, of course.
Now you have two problems.
1. The reefer quit.
2. Mama is not happy, and we all know that when Mama is unhappy, "no bodies happy."
In my 41 years with the Airstream product, I have never heard of any "burped" reefer lasting more than a couple of months.
Old 06-29-2007, 09:07 AM   #12
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Au Contraire Monsieur le RV Tech...
100 percent "on."
"Ken J" claims that a burpee on another Airstream on which he was the burper, or at least a beer slugging observer participant, is still evaporating, condensing, and cooling these four years later.
I do not intend to take the risk. I will install the new one, and keep the old plugged into 110 volts AC and 12 volts DC, collecting data all the while.
Ken L
1966 Tradewind 24
Old 06-29-2007, 09:39 AM   #13
Excella CM's Avatar
1978 31' Excella 500
Venice , California
I did my big Servel at home years ago and it has gone on in burpetuity.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-29-2007, 11:07 AM   #14
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Ken J.
If you had the six packs you might have tried to burp it without removal from the trailer.
Richard
Replacing RM100 fridge....troubles? JohnGalt48 Refrigerators 3 04-18-2004 07:13 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
RV Ideas to consider ??? FrankR General Repair Forum 18 09-18-2002 10:43 PM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 06:34 PM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 06:44 AM
