08-07-2015, 08:07 AM
Biloxi
, Mississippi
Mystery wire
Yesterday while replacing my thermistor discovered a blue wire to nowhere coming out of the controller board box. It is listed as #7 blue in the schematic. Any clue as to its function?
MICHAEL
08-07-2015, 12:10 PM
I'm In
, Kentucky
I have one too, It's a test lead. In the schematic, at the end of the wire it has a 'T', and the diagram says "Test Point"
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
08-08-2015, 05:47 AM
Biloxi
, Mississippi
Rich, thank you.
MICHAEL
08-08-2015, 07:54 AM
Princeton
, New Jersey
Mike
What caused you to change the thermistor? I have had questions about mine for some time. How much trouble was it to get it through the wall?
2004 Excursion 4x4
08-08-2015, 09:05 AM
Biloxi
, Mississippi
I wanted to be able to adjust the temp. Sliding the thermistor up or down was not doing the job. I used the snip-the-tip adjustable thermistor that does not have to go thru the wall. Wire is cut and new adjustable thermistor is spliced in using supplied screw on water resistant splices. 5 minute job. Trick now is getting it properly adjusted with the temps being so hot and the sun on the fridge side. A local RV HVAC tech recommended it.
Product Listings for Snip The Tip
MICHAEL
08-08-2015, 09:08 AM
Overland Adventurer
2009 34' Panamerica
Telluride
Mystery wire
It's a 5 minute job. There is a grommet that needs to be pushed out then the wire pulled from behind the coils, reverse to replace. I believe the value is at 90 ohms at 72 degrees.
DigiKey has them for less than $2, just solder in the replacement.
08-08-2015, 09:10 AM
Overland Adventurer
2009 34' Panamerica
Telluride
The blue wire indicates gas solenoid operation, basically an on off test lamp wire.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Excella Mystery Wire
BobExcella |
Electrical - Systems, Generators, Batteries & Solar |
3 |
08-28-2014 07:28 AM |
'89 Excella, Mystery wire bundle, hitch area, photos
cjack99 |
1987 - 1989 Excella |
3 |
01-27-2011 04:03 PM |
Mystery Wire
Hansom-Man |
General Repair Forum |
4 |
10-25-2010 06:46 PM |
Two wire and three wire converters???
max7 |
Batteries, Univolts, Converters & Inverters |
1 |
02-28-2008 05:27 PM |
Wire ,wire, oh wire can it be ?
69 Silverback |
8 |
05-15-2003 11:09 AM |
