Old 07-16-2011, 07:32 PM   #1
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Mystery Refrigerator Problem Solved
Lucy's refrigerator has always worked great on both AC and gas until last week over in Houston. Rather suddenly the refrigerator portion was only maintaining 50 degrees, yet the freezer section was at Zero. This was baffling as either both should work or neither. I tried everything, including restarting the whole unit. Nothing seemed to work. Finally, by accident, I discovered that the interior light switch had malfunctioned and was not turning off the incandescent bulb. This bulb gets quite hot and was capable of preventing maintenance of proper temperature. I removed the bulb, and several hours later, Lucy's refrigerator was back to 30 degrees in the lower box.
Brian
SuEllyn & Brian McCabe
Old 07-16-2011, 07:41 PM   #2
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
BULLS GAP , Tennessee
Glad you found out before a costly service call was in the works.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 07-16-2011, 08:11 PM   #3
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
See, if ya'd had an LED bulb in there, it probably wouln't have mattered! But good that you figured it out. Never heard of that before, but I learn someting new every day! Thanks for the heads-up to the rest of us.
AirsDream is offline   Reply With Quote
Old 07-17-2011, 12:00 AM   #4
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Anyone ever put a CFL bulb in their fridge? They operate significantly cooler.
Phrunes is offline   Reply With Quote
Old 07-17-2011, 12:26 AM   #5
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Somebody test that, I want to know if those things really will eventually come on and light outside when it's cold and you're checking to see if it's a raccoon or skunk or a bear in the back yard. More than once I'm glad I wired up a switch on the inside of the back door to see what was in the back porch before I opened the door. Raccoons will look at you and say, you looking at me? Skunks will wander off if you rattle the door. Bears will look at you, and take their time to leave just before you finally get the dam digital camera to click.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 07-17-2011, 08:56 AM   #6
richinny's Avatar
2011 34' Classic
lewster has posted on that issue before. i think the light is also used to warm the fridge in cold climates to get the fridge to cycle.
some day, a fridge manufacturer will build in a fiber optic indicator to answer that age old question of "Does the refrigerator light go out when the door is closed?". :-)
Ricky
Old 07-17-2011, 08:58 AM   #7
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Brian
Brian,
We have exactly the same scenario in our refrigerator. It's on my list to try to repair that switch. Our bulb is out now, too.
Linda Heuer. Past President Shen. Valley Unit
Greg Heuer, 1st VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 07-19-2011, 08:23 AM   #8
2011 31' Classic
Images: 8
Got Switch Out = No Way to Fix?
I successfully removed the Dometic RM3862 light switch. I tried to pry it open, but could not/would not force it. Does anyone have advice on how to fix?
Old 07-19-2011, 09:48 AM   #9
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Dometic switch
Try this.
http://www.airforums.com/forums/f313...ml#post1009393
Dave
Old 07-19-2011, 10:30 AM   #10
2011 31' Classic
Images: 8
OK, we'll try various concentrations of baking soda in water, with a forced air dry afterward. Thanks for the link.
Old 07-19-2011, 11:03 AM   #11
masseyfarm's Avatar
Images: 56
I've had good luck getting Dometic parts from this source.
WWW.RVPARTSAROUNDTHECLOCK.COM
Kim will give you a good deal.
Dave
Old 07-19-2011, 11:09 AM   #12
twobikes's Avatar
1997 25' Safari
Montgomery , Alabama
Brian, was it a little tight getting into that fridge to see if the light goes out?
twobikes is offline   Reply With Quote
Old 07-19-2011, 11:17 AM   #13
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
My fridge uses a 12VDC bulb, thought all CFL's were 110VAC.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 07-19-2011, 11:22 AM   #14
masseyfarm's Avatar
Images: 56
With climate change on the way, you need that bulb for proper cold weather operation of the fridge.
http://www.airforums.com/forums/f425...tml#post924570
Dave
Help solve the mystery... Please!!!! streamquest Vintage Kin 14 11-18-2011 08:26 PM
Mystery Wires? jambie 2005 and newer - Bambi all models 4 04-09-2011 09:29 PM
AS280 - Mystery Button on Dash dalefox Classic Motorhomes 42 03-15-2011 06:24 PM
Right brake light outage, mystery solved. DaveFL General Motorhome Topics 1 02-21-2011 01:26 PM
Mystery Door Leak - Help Needed MDSilverado Leaks - Weatherstrips, Gaskets, Caulks & Sealants 17 02-14-2011 02:11 PM
