10-17-2016, 11:28 PM
2013 30' Classic
Greenwood
, Mississippi
My refigerator isn't working
My refrigerator stopped working on propane in August.
Furnace, cook top (except front burner igniter) and water heater work on propane.
Now it seems to not work on electric, either.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
10-18-2016, 12:40 PM
Vintage Kin
Fort Worth
So far as I can tell, a rebuild isn't much worthwhile (if it's a major problem). Tempting, given the price of new.
OTOH, if an electronics board goes out, they aren't cheap (I spent $300 on one a year or so back), but the money paid to a tech of twenty years experience was worth it to me as:
He had the test equipment
And knew how to use it.
This is past no physical problems in delivering gas or electric to the unit. Or that a fuse or breaker hasn't "failed".
1990 35' Silver Streak
2004 555 Cummins
10-18-2016, 03:03 PM
Sag Harbor
, New York
Spider nests in the flue maybe per that other thread?
Originally Posted by OTRA15
10-18-2016, 05:18 PM
2013 30' Classic
Greenwood
, Mississippi
How fast can spiders build nests?
It worked on propane on a Thursday afternoon and then wouldn't work on propane Friday.
It was a sudden death.
An RV shop suspects the control board is going bad. The first tell tale sign was the light quit working.
As of this morning it was working on electric.
My trouble is I'm geographically challenged. 2 hours/100 miles from an RV repair shop.
TAC #MS-10
Airforums #70955
10-18-2016, 05:29 PM
Vintage Kin
Fort Worth
Then diagnostic equipment may pay for itself.
Ck "exerciser" under that category.
2004 555 Cummins
10-19-2016, 12:38 PM
2000 34' Limited
1985 25' Sovereign
LaGrange Highlands
Look up Dinosaur Electronics Inc they have the best boards at good prices for refrigerators and everything in the RV.
Do not get a rebuilt unit they do not last. Voice of experience.
10-19-2016, 01:38 PM
2013 30' Classic
Greenwood
, Mississippi
I have also heard not to get a "universal" board but to get a board for my specific brand and model.
If it will continue to work on electric I will wait till next year just before we pull to Texas in October.
Supposedly the boards are $300 from Dometic but $110 from an internet source.
TAC #MS-10
Airforums #70955
10-19-2016, 02:16 PM
1967 26' Overlander
Spartanburg
, South Carolina
Spiders can build webs in only an hour or two. Dirt dobbers take a little longer. If the burner has a flame but not cooling, try cleaning the flue pipe with a few feet of piano wire with a one inch ball of steel wool on the end. Remove or cover the burner with aluminum foil when doing this. If there is flame and the flue pipe is clean the orifice in the burner may be partially clogged. Do not try to clean it mechanically, instead remove the burner orifice and immerse it in denatured alcohol over night then blow it out with compressed air. If you don't have an air compressor use canned air from a computer store or Wal Mart.
The flue pipe cleaning also helps when using electric power. My electric heating element is a standard Calrod element which can be removed and checked with a volt/ohm meter and replaced if needed. Available at most electrical supply distributors. Mine was $70 as I recall.
Keep in mind that my reefer is a 50 year old Dometic with no electronics at all.
My igniter is a 12 volt hot water heater re-igniter powering a sparker from a gas grill mounted right at the edge of the gas flame. I installed the re-igniter when the old flint lighter wore out and I got tired of using matches. We have managed to keep it going all these years mainly by ensuring that it is never allowed to be turned on when out of level for more than 15 minutes and following the above preventive maintenance practices twice each year. Needless to say the trailer is a family heirloom.
10-19-2016, 09:41 PM
1977 Argosy 28
Euless
cleaning flue and burner tube with shop vac.
See if you can clean out the burner and the burner tube. Mine quit working on a 7 week trip this summer. I tried the following with mixed results.
1. first I blew out the burner tube with a computer aerosol air spray cleaner and got a lot of dirt out of the tube. My burner is sealed in the flue tube and I can not physically clean it out. The vent is a screen in the floor so I assume it sucks dirt in when I drive down dirt roads with the propane burner on. It worked for a couple of weeks and then repeat spraying did nothing.
2. Second try - My son is a trumpet major and a flexible trumpet cleaning tool with a little brush on the end is the just the right size to run up and down the burner tube. I didn't even have to take anything off except the outer metal wind shield. I blew it out again and it worked about a week.
3. The last attempt which did work was this. My refrigerator is on the end of the cabinet so I took the side off of the cabinet so I could get to the flue and pulled the rod with the spiral deflector out the top, cleaned it then took a shop vac with a cone shaped fitting on the end (available at big box hardware stores) which just fit over the flue. I blew out the flue for a couple of minutes then reversed it and sucked any residue out for a couple of minutes and put it all back together. Do this with it turned off. Also if you have been running it on electric be very careful of the adjacent tubing. I got a nice 3rd degree burn on one finger from touching the coolant tube above the flue.
It now works perfectly and the fridge runs between 32 and 38 on propane depending on how hot it is in the trailer.
10-20-2016, 05:49 AM
2013 30' Classic
Greenwood
, Mississippi
Could that much dirt accumulate in the burner in a trailer that is used every week/weekend?
Maybe when it stayed 28 days at an RV shop that did nothing, but charged me $390?
For less reason Han $390 I could self diagnose and repair if I had a little more know how.
TAC #MS-10
Airforums #70955
10-20-2016, 06:12 AM
Sag Harbor
, New York
So that's where the spiders hopped aboard!
10-20-2016, 07:15 AM
2013 30' Classic
Greenwood
, Mississippi
Maybe.
I'll check it out this weekend.
TAC #MS-10
Airforums #70955
10-20-2016, 07:29 AM
2008 25' Classic
Full Time
So the flue and the cooling tubes are not getting hot?.
Kelvin
10-20-2016, 12:03 PM
2015 28' Flying Cloud
Durango
My fridge acted up last year. Functioned on electric but not on propane. The cause was scaly clay debris which built up in the burner chimney. We do a lot of non-paved travel in CO and UT.
A local mobile RV tech blew it out and all was well. Fairly common, according to him.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
10-20-2016, 12:06 PM
2013 30' Classic
Greenwood
, Mississippi
I'll check it out Saturday.
TAC #MS-10
Airforums #70955
10-23-2016, 07:17 AM
2013 30' Classic
Greenwood
, Mississippi
The display is flashing "LP".
All the book says is "propane function locked out".
Why is it locked out?
How do I unlock it?
Everything inside looks clean.
It is warm where the propane comes in like the pilot light - if there is a pilot light - is lit.
I don't want to take it to another shop who will keep it 28 days, do nothing or make it worse, and then charge me $390!
I would have been better off to do nothing.
I replaced the tongue Jack myself anyway after the RV repair shop made it worse.
Charge me money to make everything worse. What a concept.
The initial complaint with the refrigerator was that the light didn't work. The repair shop said the board was "pinned incorrectly ". That is hog wash, because the light still didn't work, and it has never worked on propane since the RV shop "re-pinned" the board. The light worked for the first 2-3 years is why I know the "board of as pinned incorrectly" is a bunch of baloney.
I really don't understand what I am looking at.
I don't understand how to gain access to the burner, board, or flue.
Hoping someone here will know what to do- where to guide me or direct me, or point me to an honest repair shop.
TAC #MS-10
Airforums #70955
10-23-2016, 08:32 AM
2015 27' Flying Cloud
Newberg
, Oregon
Maybe this will help?
Mike
10-23-2016, 08:56 AM
2012 25' Flying Cloud
Berlin
, Maryland
As others stated it does not take long for a spider to build a web or to get inside things. As to the light IMO it is a seperate issue. I had my door light go out a year or so however the refrigerator still worked. It is asy to replace.
If you are getting propane to the stove, the furnace and hot water heater then you know the propane is flowing. I was told my Colonial Service Dept that when I have a problem with the refrig not working on propane and I know the propane is flowing to shut down the refrig for at least ten seconds and turn it back on LP. Some times it might take more then once but it has worked for me in the past. Not sure why however I believe it has something to do with an airlock. Others might chime in as to why this works.
10-23-2016, 09:38 AM
2013 30' Classic
Greenwood
, Mississippi
It isn't the light bulb.
TAC #MS-10
Airforums #70955
10-23-2016, 09:39 AM
2013 30' Classic
Greenwood
, Mississippi
I will try turning it off for 10 seconds- when there is no groceries in there-
Maybe that is a reset procedure?
TAC #MS-10
Airforums #70955
