Old 12-18-2007, 12:03 AM   #1
Mound , Minnesota
My Klixon Valve Leaks! What do I Do????
I have a gas leak on the assembly my klixon valve as shown in the picture. Does anyone know how I remove the burner barrel or fix the leak? I Tried unscrewing it and it just spins. Any help would be greatly appreciated!!!
hdgirl1340 is offline   Reply With Quote
Old 12-18-2007, 01:25 AM   #2
calitrotter
1963gt's Avatar
Berkeley , California
lift it off
after you have unscrewed it you must lift it up and off.
i have removed mine several times.. my porcelain burner is cracked..
maybe your burner is dirty or clogged and that is causing it to leak at the bottom..
mike
1963 Globetrotter OHIO
1988 Ford E150 Sportsmobile
2001 Buell X1 Lightning
2002 Isuzu Axiom 4x2
1963gt is offline   Reply With Quote
Old 12-18-2007, 05:09 AM   #3
Mound , Minnesota
lift it off?
I tried pulling it up. It just doesnt seem to want to come up and the ring that turns doesnt want to tighten back down either. am i doing something wrong? I'm scared that i might damage the porcelain or damage the tang on the klixon valve.
Leaks, and leaks again danesh Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 09-08-2007 08:32 PM
Leaks Sundance Sinks, Showers & Toilets 4 07-03-2007 02:47 AM
Today gate valve, later check valve. GlenCoombe Classic Motorhomes 1 09-20-2005 11:02 AM
Leaks! 1956Safari Leaks - Weatherstrips, Gaskets, Caulks & Sealants 24 03-31-2005 07:39 PM
leaks Larry Leonard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 11-03-2003 03:09 PM
