Old 08-07-2004, 04:21 PM   #1
John Greenlee's Avatar
Bowie , Texas
My fridge doesn't work on AC...
...but this appears to be because of a disconnected wire. I need to get the fridge out to see the wiring panel on the back to make sure I hook it up correctly. Anything I need to know to get the dometic fridge pulled out? Any other advice?
JMG
John Greenlee is offline   Reply With Quote
Old 08-08-2004, 12:13 AM   #2
Hippo's Avatar
Battle Ground , Washington
Mine does not work either on AC. I replaced a toggle switch on the controller for gas or AC. It still does not work. Runs fine on gas.
If you find out anything let me know.
Hippo
Hippo is offline   Reply With Quote
Old 08-08-2004, 07:13 AM   #3
Arr, we captain our ship!
Xray's Avatar
Santa Fe , New Mexico
Images: 44
Mine didn't work on AC once either yet it was fine on gas... I took it to the dealer and he found nothing wrong. Funny, started working again when I made sure we were dead level.
Are you level?
X
Xray is offline   Reply With Quote
Old 08-08-2004, 10:49 AM   #4
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
JMG, pulling the fridge is quite a job. Have you opened the exterior fridge access door and looked around?
The Dometic fridge in my Caravel didn't work on AC when I got it. I opened the access door and found a disconnected ground wire.
All better now.
Rog
May you camp where wind wonít hit you, where snakes wonít bite and bears wonít git you.
Rog0525 is offline   Reply With Quote
Let's start with the Fridge.... GT1963 Refrigerators 6 03-03-2004 09:01 PM
Fridge replacement/ Inverter needs rdm General Motorhome Topics 4 01-20-2004 06:04 PM
First pipes now fridge... overlander76 Refrigerators 8 11-24-2003 01:46 PM
Fridge doesn't work on ac jwaldin Refrigerators 5 04-10-2003 10:38 AM
