Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 05-16-2007, 07:32 PM   #1
Profile:  1963 28' Ambassador
Albuquerque , New Mexico
model number for 1963 Dometic?
Our '63 Ambassador came without the fridge, and we'd like to try to replace it with a used one. Does anyone know the original model number for the Dometic refrigerator for this trailer? Searching the forums I came up with RM35 as a possibility. Has anyone had luck finding a used refrigerator from that era? The cabinet dimensions we have, which may have been modified, are 21 " wide, 24-25 " deep, and 25 -47" tall (depending on whether we have to remove a bottom shelf and drawer.) Any advice would be appreciated!
campbell is offline   Reply With Quote
Old 05-16-2007, 07:44 PM   #2
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Airstream Registry
The RM35 nominclature is, I believe for a 3.5 cu.ft. fridge like in our '64 GT. Your Tradewind would have had a larger one, as each incremental size of trailer came with a incremental sized fridge "back in the day".
Yes, firdges of this era can be found at RV salvage yards, however, most will be in a sorry state of disrepair. If you do find the right one, if can sometimes be fixed, however it is costly to do so.
Your best bet IMO is going to be to place an ad in our "wanted" section of the AirForums classifieds. Maybe someone with a similar age trailer will be stripping their guts out for a remodel and will have a donor for you.
Good luck in you quest!
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 05-17-2007, 03:21 PM   #3
Thanks, Shari. I didn't know how easy it would be to find one, but I had to start with finding out what model we needed first. We may end up with a cooler in the back of the pickup for awhile. I'll try the classifieds!
Mariel
Old 05-17-2007, 03:58 PM   #4
BoiseState
Spiffy Gem's Avatar
Profile:  1966 22' Safari
All my life in , Idaho
Images: 41
I've got a used frig that came with my coach (not original), that is available. I can check the model number, if you wish.
Spiffy Gem is offline   Reply With Quote
Old 05-18-2007, 01:16 PM   #5
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 65
Airstream Registry
Here is a link to a chart by Dometic. It shows the size of many of the older units and the current models that can be used to replace them.
Dometic - Conversion Chart
Richard
Charter Member Four Corners Unit
Old 05-22-2007, 03:15 PM   #6
used fridge?
Spiffy Gem - I'd be interested in that model number, or dimensions if you have them.
Thanks!
Mariel
Old 05-22-2007, 05:58 PM   #7
BoiseState
Spiffy Gem's Avatar
Images: 41
It's a Dometic RM2501 gas electric (2way) fridge made in Sweden.
I have measured all dimensions two ways: both with and without the face/door lip.
Its unofficial measurements (my measuring) are:
Width:
Without face lip: 21.5 inches
With: 23 inches
Depth:
Without: 22 5/8th inches
With door: 24.5 inches
Height:
Without: 39 15/16th inches
With face lip: 40 5/8th inches
Calvin
Old 05-23-2007, 08:32 AM   #8
Thanks, Calvin. Those dimensions might work for us. I'll send you a private message and we can talk over the details.
Mariel
Canadian Model Airstream? 53flyingcloud Our Community 5 11-29-2002 05:00 AM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 9 10-08-2002 04:08 PM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
Fridge Cooling Problems 68International Refrigerators 6 07-10-2002 03:53 PM
Dometic Furnance Help chrisg Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-07-2002 09:34 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
