Old 10-01-2005, 09:07 AM   #1
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Low Temp Switch
The refrigerator on my Classic has a low temp switch. According to the manual, it is to be turned on when the refrigerator is operating in low external temperature situations. Interestingly enough the manual has no definition as to what "low temperature" is.
Has anyone done any study as to when to activate this switch and more importantly, what does it really do? I've never used it.
My gut feeling is it might allow the heat source to become hotter than normal to compensate for lower temperatures of the ammonia water mix.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-01-2005, 01:25 PM   #2
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Jack,
I think that it either activates a small heat strip in the storage compartment or simply keeps the fridge light on with the door closed.
It has to do with cold air infiltration from outside acting on both the freezer and fridge compartments, which tends to make them both nearly at the same temperature, I'm guessing. Maybe the fridge just needs a little warmth to keep it operating.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Univolt Low Buzzing Noise rjones1138 Electrical - Systems, Generators, Batteries & Solar 23 07-16-2003 06:23 AM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 08:47 PM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
