Old 06-28-2007, 09:49 AM   #15
rambn's Avatar
2007 19' Bambi
el centro , California
Originally Posted by Gen Disarray
As a former firefighter/medic, I have no desire to be that historic first case....All joking aside though, I would rate running a refer while fueling to be like smoking there. Why risk it?
Or my personal favorite, people that talk on their cellphones while fueling.
rambn is offline   Reply With Quote
Old 06-28-2007, 10:00 AM   #16
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Originally Posted by HiHoAgRV
FYI the most analytical unit I've seen so far to describe "level" is a round type bubble level, in the center of the freezer compartment floor, must have at least 3/4 of the bubble in the ring.
I was hoping there was a more defined specification.
Here is a link to one.
Save at RV Partscenter - RV Parts and Supply
Jack
Jack Canavera
STL Mo.
AIR #56
jcanavera is online now   Reply With Quote
Old 06-28-2007, 10:10 AM   #17
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Pretty much what has been said. Comfy for new, level for older units.
Old 06-28-2007, 10:44 AM   #18
1962 19' Globetrotter
shickshinny , Pennsylvania
Thanks to all for answering my question... After being very stupid at 19 and steam burning off 1/2 my skin from calf to ear on the right side of body (took a radiator cap off a overheated personell carrier with the toe of my boot) I was a long time recovering. Lesson: better safe then sorry is well learned. I opt to not refuel with an open flame anywhere near.....if I can remember! Lance
LanceW is offline   Reply With Quote
Old 06-28-2007, 11:06 AM   #19
2005 30' Classic
Images: 12
Installed a new Norcold (model 510). The manual said 3 degrees tolerance, curb side to street side of the TT (front to back, back to front of the fridge), and 6 degrees the other way.
Also been talking with the local dealer, where I bought the fridge (new fridge needing new parts - for the third time - they haven't figured out what is wrong – go figure). With limited level tolerances, traveling with the fridge working on gas can cause it to lock up, as no road is built with the idea of staying within the 3 degree thing for RV’ers. The service dept. says they fix about 2 units per season that have had this happen.
I recently read a thread here where the tanks came loose and would have caused a fire if the tanks were turned on and in use.
The service guy was very much against using the fridge while in transport.
Is it really worth the risk? Is it really that important to run the fridge in transport? If it is, maybe the use of ice (dry or otherwise) would be better.
GetOutDoors is offline   Reply With Quote
Old 06-28-2007, 01:21 PM   #20
Any "good" reefer can operate considerably off level for 15 to 20 minutes without locking up.
Thousands of Airstreamers do that all the time, without a problem.
Traveling with the gas on, is OK, except when in a tunnel. You are supposed to make sure everything on your trailer is secure, including the LPG bottles. Thousands of Airstreamers do that too.
For that matter, if the bottles were shut off, and they came loose and hit the ground, you still could have a fire or explosion.
Sounds like the service guy doesn't know much about RVing, or Airstreaming.
Gosh, if we should worry about what "could" happen with the LPG system, then perhaps we should also worry about the other fools on the highways, that "could" hit us head on. They are by far, a greater hazard than a secure LPG system could ever be.
Have things secure, keep the running gear properly balanced (so that you don't shake things loose), and enjoy your Airstream with your family and friends.
Old 06-28-2007, 01:58 PM   #21
2005 30' Classic
Images: 12
Andy,
You are a good guy, but sometimes you confuse me: are you the same Andy making a stand for safety in http://www.airforums.com/forums/f438/tires-tires-tires-16506-3.html?
I'm no expert - that's why I have to depend on the installation and owners manual from the manufacturer of the product and hope to gain proper knowledge by talking with the people who are the 'supposed' experts. And when the ‘experts’ exert themselves, and are proved to be wrong – well people like me, in an effort to keep from being taken advantage of, become a little skeptical.
That said, as far as the fridge lock-up thing goes, I guess it, in part, depends on where you live: if the flat plains make up your neck-of-the-woods, then I guess you don't need more than 15-20 minutes of grace without the "good" reefer locking up. In my neck of the woods, where roads follow rivers and ridges and are far from level, the dynamics change: to get to the good places you could be climbing or descending a steep (6-8 %) grade for hours.
Lastly, I have also been told that there are only two choices of ‘reefers’, Dometic and Norcold. So, what make is the ‘good reefer’? My experience with Norcold, thus far, is 100 percent bad.
Old 06-28-2007, 02:14 PM   #22
Andy,
As long as the trailer is in motion, the off level does not matter. You can tow that way for hours without any ill effects. Why? Because the motion is keeping the ammonia/water solution moving. When the off level "does" matter, is when the trailer is stationary.
Dometic and Norcold are very good brands of reefers.
Perhaps the shop is the problem?
Wouldn't be the first, or the last time.
Old 06-28-2007, 02:29 PM   #23
2005 30' Classic
Images: 12
Thanks Andy.
Interestingly enough, I looked up the owners manual online (N500 Series).
On page four (lower right column) it has a section called 'leveling', which is where it says 3 degrees off-level side-to-side, 6 degrees off-level front to back. Just below that it states: "Operation During Travel: While the refrigerator should be level when the vehicle is stopped, performance during travel is not usually effected."
So, it looks like they endorse the use/operation of the reefer during travel, and clause themselves out of liability with a 'not usually effected' statement.
Old 06-28-2007, 02:48 PM   #24
Thanks Andy.
It's nice to have a post quoting a manufacturer.
In this case, what I said is not an opinion, but fact.
What your service man said, was an opinion, not fact.
I am sure your findings will now allow you to enjoy your Airstreaming, even more.
Old 06-28-2007, 05:38 PM   #25
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
reefers and tunnels
That's a new one on me. Is this a law, or a safety procedure? If a law I would guess it varies from state to state.
Also, another post above mentioned using a cell phone near a gas pump. I will bet a buck there has never been a case of a cell phone starting a gas pump fire
Old 06-28-2007, 09:30 PM   #26
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Marshall, I wish I had my Commercial Road Atlas handy. My son is at the drive-in with his fiance and he has my truck. That Atlas lists a number of tunnels which forbid any LPG tank to be turned on while going through the tunnel. The Holland Tunnel comes to mind. I know that other forum members have this atlas because comments have been made about locations, by State, of low bridges. Maybe someone else has one available to give some of those locations.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Replacing RM100 fridge....troubles? JohnGalt48 Refrigerators 3 04-18-2004 07:13 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 06:34 PM
Battery Level Display uwe Electrical - Systems, Generators, Batteries & Solar 4 07-04-2002 07:31 PM
Help with Coolant Level winner Mechanics Corner - Engines, Transmission & More... 6 04-24-2002 04:47 AM
