Old 07-16-2014, 01:17 PM   #1
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
KREFFT help!
I am starting work (again) on our 1958 18' "Traveler". It has the original Krefft Refrigerator. I am currently working on the 120 Volts and LPG Systems and could use some help from others with this refrigerator.
I had the Cooling Unit repaired and it now works with the Heater installed as a test only. I am going to wire the Thermostat for the 120 Volt System later today.
The Instructions state to "ELECTRIC HEATING UNIT MUST BE REMOVED BEFORE STARTING ON GAS" so that is self explanatory. I do not have any Ducting from the Heating Section to the Roof Vent. Could someone post pics of their installation?
Here is an earlier pic with the Krefft still in the Traveler.
thanks in advance
Name:	1958 Airstream Traveler 007.jpg
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 07-16-2014, 04:56 PM   #2
1958 18' "Footer"
I was able to copy and then scan the Instructions (1st pic). I also found some other images that could be helpful to others.
ID:	216482   Click image for larger version
Name:	1958 Airstream Traveler 023.jpg
Name:	1958 Airstream Traveler 027.jpg
ID:	216484   Click image for larger version
Name:	1958 Airstream Traveler 024.jpg
Steve
Old 07-17-2014, 06:52 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I have a Kreft fridge - a slightly different model but I know what that means. Ours has an electric heating element that has to be removed when using the fridge on gas too. It is a long, flexible tube that plugs in to the fridge back & goes into a cylinder on top of the fridge. See the pics below.
If you don't have the electric heating element part, you won't be able to use your fridge on electric - gas only.
Hope this helps ~
Shari
Note to self...clean top of fridge!
ID:	216562   Click image for larger version
ID:	216565   Click image for larger version
Old 07-17-2014, 06:57 PM   #4
1958 18' "Footer"
thanks and yes that does help!
My Thermostat is bad and I will need to replace it (as soon as I can find a replacement). Where is your Thermostat for the Heater Element?
I noticed that your Refrigerator isn't vented any further that the Refrigerator itself. I was thinking of Ducting mine closer to the Vent Fitting.
What do you think? (do you have Carbon Monoxide Detectors?)
PS is that a Digital Thermometer or Thermostat you are using?
Steve
Old 07-17-2014, 07:06 PM   #5
InsideOut's Avatar
1956 22' Safari
Images: 108
I'm not sure I understand your question...ours has a "chimney" that goes to the roof vent - are you saying yours just vents into your trailer? I have seen that before, but ours has a pseudo-vent - not air tight, but I think better than nothing. We always have a window of vent cracked so I'm sure all is well.
Our chimney is original and just made from aluminum sheet. It has the access door on the inside (open for the pics) so you can put the electric heating element in place and louvered vents on the exterior to get the airflow moving.
We were missing the electric heating element when we first got our trailer - but found one at an ol' time RV shop a couple of years ago. We do find we usually only use our fridge on gas though...don't know why other than our other trailer only had gas so that is what we are used to and we camp without electric hook-ups more than 50% of the time.
Shari
Old 07-17-2014, 07:26 PM   #6
COLONEL's Avatar
1958 22' Flying Cloud
Lincoln City , Oregon
Steve,
I have exactly the same Krefft as yours in our 1958 Fling Cloud. Ours has a vent to the outside (street side) and it also vents to the trailer top behind a drawer. We do not keep bread or chocolate in that because it gets too warm.
We have been traveling since 28 FEB and have been using the LPG constantly since then. Good luck with yours.
Dick
COLONEL is offline   Reply With Quote
Old 07-18-2014, 06:53 AM   #7
1958 18' "Footer"
Thanks guys!
Shari, the 3rd pic shows your Ducting or Chimney? looks like it is the dimension of the entire back of the Refrigerator, if so it answers my question. May be more difficult on mine because of the Cabinetry although looks safer that how mine came to me.
Looks like there is a Louvered Vent from the outside right behind the Refer. I have a Hole in the Floor and then an Access Door that is lower than the Refer.
Colonel, sounds like yours is in a Cabinet and elevated similar to ours except on the other side. Still helps to answer my question. Could you shoot me a picture or two of the Chimney when you get a chance so that I can build one
I put my Thermostat Probe in Ice yesterday and checked the Contacts on the Switch, Bad Switch! Now on a hunt for a replacement Thermostat but that shouldn't be too difficult.
I need to still Figure a way to test the Gas Valve since the Cooling Unit was bad and only heating up the interior of the fridge. Hopefully the Gas Valve is still in good condition.
Steve
Old 04-19-2015, 10:20 AM   #8
1958 18' "Footer"
The Krefft cabinet is getting ready for paint.
I started the testing yesterday with a new Dometic #3890032-02/8 Thermostat. The 120 Volts AC System is working well with the Cooling Unit out of the Cabinet.
The LPG System is unique on these!
The is a Type TZ Burner. This Burner starts the flow of propane after it gets hot and shuts it down after it cools off. After testing this operation numerous times it appears to be functioning.
There is a Type TP Valve that adjusts to the temperature although mine looks to be faulty because the Flame doesn't Adjust.
Not sure what I am going to do about this just yet but I have found a manual and wanted to share it.
Steve
Old 04-20-2015, 01:16 AM   #9
1958 18' "Footer"
Just saw this posting on another forum, ooks like Norcold and Krefft are the same!
Norcold Gas Refrigerator Manual | Vintage Trailer Talk
Steve
Old 04-21-2015, 08:29 PM   #10
1958 18' "Footer"
Please check my restoration pages for more.
Steve
Old 07-31-2017, 02:15 PM   #11
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
I'm tagging onto this post, hoping that someone else might have an element laying around they'd sell. I'm putting up a want ad too but here's hoping!
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 08-01-2017, 08:34 AM   #12
57Vintage's Avatar
1957 26' Overlander
Battle Ground , Washington
Images: 21
Kreftt venting
Steve my 57 doesn't have a duct to the roof. Just the shelf above the frig (with a gap at the back if I remember correctly) and the screened oval opening, with the large oval hat on top of the roof.
ID:	291025   Click image for larger version
57Vintage is offline   Reply With Quote
Old 08-02-2017, 07:41 AM   #13
1958 18' "Footer"
57Vintage & other Krefft owners, please check my restoration pages. I have finished the ventilation that I believe meets the newer standards. I hope that they will be helpful.
Steve
1956 Krefft Refrigerator ericp755 Refrigerators 9 05-01-2017 08:00 AM
Krefft fridge Deluxe21 Refrigerators 2 08-21-2008 09:06 PM
Krefft Refrigerator prairieschooner Refrigerators 2 09-10-2006 04:03 AM
Help Help Help!!! rebel beck 1974 - 1979 Sovereign 9 01-07-2006 03:00 PM
