Old 01-24-2014, 10:23 AM   #1
1960 24' Tradewind
Alabaster , Alabama
Is this a Klixon valve problem?
So I have this fridge, that is period correct for my 1960 Tradewind, a Dometic taken from a 59 Airstream. It is LP-only, and the back looks very good. No ammonia smell, etc.
So when I hook it up to gas and light the pilot, the pilot will stay lit, but nothing else happens. I have never played with a fridge this old, so I'm worried I'm missing something. From reading on the forums it seems this could be a Klixon (sp?) valve problem, but would a broken thermostat have the same effect?
I should probably just find a new model that fits in the space, but this one is so cool looking, and would be enough space for our family's adventures...
Any help would be greatly appreciated. Thanks!
Brian
sbrianericks is offline   Reply With Quote
Old 01-24-2014, 10:55 AM   #2
1960 24' Tradewind
Alabaster , Alabama
After reading some more of the service manual, I went back and looked more closely at my Klixon valve. It looks like the tongue is toast, so I'm guessing this is just dead, right? No replacing this thing?
Old 01-24-2014, 11:12 AM   #3
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
Sorry I can't help much. I managed to get mine to run this past Spring, but that was just luck, not knowledge or skill. You probably have already seen this manual, but I'm attaching it here if that helps.Dometic Refridgerator Service Manual.pdf
Thalweg is offline   Reply With Quote
Old 01-26-2014, 05:56 PM   #4
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Yep looks like klixon. I can't tell by the pic about the tongue. 1st be very gentle with it, it can't take much bending it will break. I've had some luck with these. Usually the burner/orifice is plugged Needs to be removed and cleaned. If the tongue is broken off you can form a C shaped collar and tongue from soft aluminum that will slip over the existing aluminum. Well matched and secured with a mini worm drive SS clamp it will transfer enough heat from the pilot flame through the existing alum ring to the "bi-metal" disc to "click" open the gas valve. Above all else be very gentle with the entire unit, parts are not to be had. If you see even a tiny dot of flame escaping around the perimeter of the bi-metal disc scrap it, not safe.
putback is offline   Reply With Quote
Waste Drain Valve Replacement BarnacleBill Land Yacht/Legacy Motorhomes 36 03-17-2013 07:10 PM
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
New black water valve on a 1962 Bambi? female.nomad Waste Systems, Tanks & Totes 1 09-26-2011 10:28 PM
How to disassemble a drain valve flyflinger Fresh Water Systems 2 09-25-2011 11:17 PM
Black water tank valve flange Safari64 Waste Systems, Tanks & Totes 1 09-22-2011 07:50 AM
