Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 10-02-2003, 09:09 PM   #1
Tin Hut
Tin Hut's Avatar
Profile:  2005 28' International CCD
Southlake , Texas
Is my refer working?
Just tried turning on my 3 year old Dometic for the first time today on AC. I'm used the my home fridge and expected to hear some noise when I turned it to electrice and moved up the thermostat. No noise. I checked and it is getting power and some of the components in the back are hot to the touch. After 20 minutes I did not notice it getting cold. Is this normal? How long does it take and should there be fan or condenser noise similar to a house refer? Thanks
Tin Hut is offline   Reply With Quote
Old 10-02-2003, 09:17 PM   #2
wingfoot
Profile:
Mine is quite a bit older but, I hear nothing when it is operating on electric. 20 minutes is not long enough to test. I started mine today on gas and it took about 2 hours before I really noticed the freezer plate getting very cold. It took about 6 hours to get down below 30 degrees.
wingfoot is offline   Reply With Quote
Old 10-02-2003, 09:17 PM   #3
mkeith54
mkeith54's Avatar
Profile:  1976 26' Argosy 26
New Florence , Missouri
With a gas refer you won't hear any noise on start up. It can take over 24 hours to cool down so keep checking. Gas(LP) will cool faster that electric mode.
Mike Keith
75 Argosy 26'
96 Ford F-250 PowerStroke
WBCCI 4503
Gr8r STL Unit
mkeith54 is offline   Reply With Quote
Old 10-03-2003, 08:43 AM   #4
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
jfsjr,
Since others have asked the same question previously, I wrote down times and temps for both my frigerator and freezer from startup while camping a year or so ago. I did a forum search but did not run across the statistics. I did find another of my posts mentioning that on propane I waited for at least 5 hours before the refrigerator and freezer were cold. mkeith54 is correct in that there is no noise from the refrigerator unless someone has added an auxilliary fan in the outside compartment to keep the external coils cooler thus increasing your refrigerator's efficiency.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 10-03-2003, 03:49 PM   #5
Dbraw
Profile:
No cool
Our 32 year old Dometic has been working good on both electric and gas. However, a week ago I turned it on electric and it worked for about a day then the next day it was warm inside. Used it on propane at a rally and it was real cool. Hated to replace it and then remembered that we had a storm the night it quit working. Lucky us, the ground fault plug on the side of the house had tripped. Reset it and now things are cool again. Hoping for another 32 years.
Dan
Dbraw is offline   Reply With Quote
Level sensors - not working drboyd Waste Systems, Tanks & Totes 3 12-06-2003 08:16 AM
Antenna coax down refer vent. dsrtquest Audio, Video & TV 1 09-01-2003 04:24 PM
Refer heat / venting JaceBeck 1999 Safari 3 08-21-2003 09:40 PM
dometic 3way refer. will Refrigerators 3 08-23-2002 05:52 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 10:54 AM
test
