Old 07-29-2015, 01:14 PM   #15
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I think the bottom line is air movement is key... In the box and out in back!
Moving inside air helps circulate cold around objects, moving air out the vents simply draws cooler air in, obviously making things work better!
Old 07-29-2015, 01:52 PM   #16
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
We have the little fan that uses "D" size batteries and it helps a lot with keeping the air circulated. I have a little computer fan that I would like to install inside the box when I get some time and figure out where to tap the hot wire and ground.
The absolute best thing I did was remove the refrigerator and install it per the instructions. I put new insulation board along the sides, insulation above the unit and built a false wall behind the unit. There is only supposed to be 3/4" of space between the rear wall and the coils. I did install a 6" computer fan in the roof penetration but I have only had to use it a handful of times - usually during the initial cool down before a trip. Cool down is 2x as fast.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 07-29-2015, 01:57 PM   #17
dznf0g's Avatar
Oswego , Illinois
I installed bubble foil on the walls and ceiling of the compartment while the fridge was out to reduce heat transfer to the interior AS walls. Should've installed it on the sides and top of the fridge too, but didn't think of it. Not much room in my compartment sides for more than that.
-Rich-
Old 07-29-2015, 02:19 PM   #18
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
That wall is a must, but neglected by the factory! I did this and greatly improves the performance of the fridge
Old 07-29-2015, 02:34 PM   #19
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
What do you think about lining it with Reflectix? I've been thinking about doing that.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 07-29-2015, 02:35 PM   #20
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
My 25fb Classic has the false wall between the shell and the cooling unit of the fridge. Above my fridge on the inside the cabinetry will feel warm. I'm guess it must be just a void but hopefully not open to the chimney area where heat from the cooling unit can collect and intervere with the airflow in the chimney. While the Flying Cloud versions of the 25fb have a shallow cabinet above the fridge the Classics don't.
Rich, in your Classic what is above your fridge? Do you have a cabinet door. Do you know what Airstream did to close off the space above the fridge from the chimney?
Kelvin
Old 07-29-2015, 02:39 PM   #21
dznf0g's Avatar
Oswego , Illinois
No cabinet....thought about putting one in. Probably will some day, as I HATE wasted space. It is an empty cavity which traps heat and probably causes some unwanted turbulence in the airflow. I did Reflect-x it as well as the rest of the lower cavity. The deflector on the outside wall does need to stay. It helps hot air "rush" upward. A convection venturi effect. I did not insulate it as it is on the outside wall anyway and I didn't want to constrict that space.
-Rich-
Old 07-29-2015, 02:59 PM   #22
KJRitchie's Avatar
2008 25' Classic
So the cavity is not open to the chimney. There is a wall between the chimney and the cavity above the fridge?
Kelvin
Old 07-29-2015, 03:03 PM   #23
dznf0g's Avatar
Oswego , Illinois
Kelvin
Nope, it's open to the chimney area, however the roof vent is more inboard than you would think, so much of the space above the fridge box must be open. You couldn't put a very deep cabinet in....how deep is the cabinet in the other model?
-Rich-
Old 07-29-2015, 03:35 PM   #24
dznf0g's Avatar
Oswego , Illinois
That's what I used, just had a brain fart on the brand.
-Rich-
Is putting cart before the horse a good idea? Is this a good deal on the cart? cantdrv55 Buyer Guidelines 33 11-10-2014 02:17 PM
IDEA for a Refrigerator install with a 12v & solar fan BB 55 Bubble Refrigerators 12 01-30-2012 11:17 AM
Total electric. Good idea or bad idea? EZstream Generators & Solar Power 34 08-17-2011 08:40 PM
03 tundra + 63 ambassador + 2000 miles= good idea? tjj's63 Tow Vehicles 12 11-05-2007 11:38 AM
