Old 03-30-2011, 08:02 PM   #1
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
Important late model refrigerator controls
I learned this today about Dometic refrigerators, thanks to lewster, a highly esteemed Rivet Master on Air Forums:
"CLC or CLIMATE CONTROL is a switch that controls a frame heater. This switch is engaged in high temperature AND humidity conditions when moisture is found on the refrigerator frame where the door seals make contact. The moisture on the frame impairs the sealing properties of the door ... leading to air leaks, lower internal fridge temps and the formation of frost and/or icing of the cooling fins. This heater draws less that 0.5 amps
LAC /LAT or LOW AMBIENT CONTROL or TEMPERATURE is a switch that activates a circuit to bypass the door switch to allow the interior light to remain ON when the door is closed! This is done when the outside (ambient) temperature is below 50*F. The intent is to create a mild heating effect in the fridge section that will tell the thermostat to engage the cooling unit to cycle every 35-55 minutes. This will help keep the temps in the freezer (uncontrolled) in the proper freezing zone. In low ambient temps, if this switch is not engaged, the fridge will stay cool, the cooling unit will not cycle, and the freezer will warm beyond its acceptable range. It also keeps the cooling unit from freezing (there is water in the coolant mix) by cycling the cooling unit.
This switch should not be operated if the ambient temps are above 50*, as it will negatively affect the cooling operation of the fridge."
Name:	Airstream pick-up 057.jpg
JBinKC is offline   Reply With Quote
Old 07-09-2011, 10:23 PM   #2
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
JB,
Thank you for the information on the LAC control. We recently purchased a 2005 Classic that has the Dometic refrigerator with the LAC mode button.
What bugs me is that the interior light does not turn on when the door is open, just when the LAC button is depressed.
I guess there is a problem with the refrigerator interior light switch. I guess I will have to take this switch apart. Any other ideas??
David
10Smiles is offline   Reply With Quote
Old 07-10-2011, 10:04 AM   #3
JBinKC's Avatar
2007 31' Classic
David: Iíll just bump this thread to keep it in front of the forum. I hope a forum electrical techie will chime in to help you find the refrigerator light gremlin. Also, you might give Airstream Support a call at 877.596.6505. Have the last six digits of your Airstreamís serial number handy. Lastly, Dometic may have tech support, but I havenít tried it. Best wishes.
Old 07-10-2011, 11:02 AM   #4
withidl's Avatar
2002 31' Classic
Houston , Texas
Very good information! I might add that on my 2002 ASCL (May 2001 build date) the 10 cf Dometic has these same switches, but instead mounting them on the front panel as per your photo, they are mounted on the top underside of the freezer door frame where they are essentially out of sight even with the freezer door open unless one purposely looks up at them; thus some of us may be unaware that they are there. The two switches are "rocker" type (black with red when on) and are labeled "Low Ambient Switch" and "Climate-Control Switch".
withidl is offline   Reply With Quote
Quality of construction late '80s early '90s trailers MrBeast General Repair Forum 7 03-06-2011 08:54 PM
Just bought a compressor, have a late model.. THEPILL Winterizing, Storage, Carports & Covers 11 01-11-2011 01:52 AM
