Old 06-15-2009, 10:28 PM   #1
swanky's Avatar
Grosse Pointe Park , Michigan
Ice maker questions
Anyone have a built-in ice maker. Ours appears to freeze well, you can hear it try to add water, but so far no ice and there is no water in the little trays when I stick in my finger. It might just end up a second freezer, but I would really love to get it working.
Any suggestions on how to check it out? The actual unit, the ice making part, does not appear to be removable like ones in your kitchen freezer. It's really cold, freezing even, inside, just no ice.
The PO never used it as an ice maker, just an ice holder and he bought a bag of ice. He didn't use the fresh water as potable water so therefore could not use the ice either. We are flushing and cleaning the fresh water tank so the water/ice will be potable if possible.
Thanks.
swanky is offline   Reply With Quote
Old 06-15-2009, 10:30 PM   #2
swanky's Avatar
Ice maker--1982 Classic Motorhome 280 Diesel
Sorry, forgot to tell what vehicle the ice maker is in...
Old 06-15-2009, 10:45 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Check for a cutoff valve in the water line. A clogged filter would imply a lot of use under dirty conditions for a complete stoppage, if ever.
Vaughan
Old 06-23-2009, 01:17 PM   #4
swanky's Avatar
Ice maker worked, then didn't...
I discovered the water line was simply disconnected and soon had a batch of ice. Then, I had a major block of ice and water/ice everywhere. The mechanism that tells it to stop accepting water is not working and it just keeps taking on water. While it freezes well, it can't keep up so we ended up with a huge block of ice in the bin, ice freezing the bin to the interior of the ice maker, and a wet carpet under the machine. I eventually disconnected the water line again as it keeps leaking whether the ice maker is on or not.
Any ideas what needs to be fixed for this issue?
Thanks.
Old 06-23-2009, 02:18 PM   #5
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Solenoid valve would be my first guess,it could have some crud in it,but it is easier to replace than to try to clean.You should add a filter to the line,if you use an inexpensive one you could throw away at the end of season to winterize,then replace it in the spring.
Hope that works,Dave
easyride is offline   Reply With Quote
ice maker
ice maker mlmarch General Motorhome Topics 13 06-29-2010 04:47 PM
fridge with or without ice maker remcolent Refrigerators 12 07-04-2008 11:18 AM
U-Line Ice maker in '94 LY blkmagikca Plumbing - Systems & Fixtures 5 08-15-2007 04:11 PM
Portable ice-maker experience? Kistler Our Community 6 06-22-2005 11:13 PM
Dometic with ice maker Minnie's Mate Refrigerators 0 09-27-2004 08:27 AM
