Old 06-08-2018, 12:42 AM   #1
1970 25' Caravanner
Incline Village , Nevada
How to wire fridge to tow vehicle via wiring socket?
Bought a Norcold N3104 3 way fridge and am stuck on how to connect the wiring for 12V use (both with tow vehicle while driving and from trailer battery when parked). Hoping someone has connected something like this before and can walk me through it.
Here is the wiring adapter on the back of the fridge along with the wiring diagram from Norcold.
Name:	fridge wiring diagram.JPG
I have a 7 pin round wiring socket and I believe this is the wiring diagram for it.
Name:	7 pin rounded connector wiring diagram.jpg
The part I am most confused by is the HC+/HC-/D+ connections. Are these standard and already wired into the wiring socket from my tow vehicle? If so, which pins do I connect the wiring from the fridge to? If not, is this something than can be wired into the wiring socket from the tow vehicle or does it need its own set of wires?
Thanks for any help.
Jeremy9107 is offline   Reply With Quote
Old 06-08-2018, 07:08 AM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Unfortunately, the resolution on your Norcold schematic is too low for me to read. Can you post a higher res version? I do not think the wiring will be that difficult.
Tom
Old 06-08-2018, 07:23 AM   #3
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Ok so here goes,
LC+ and LC- go to the trailer + and - connection
HC+ goes to the blue aux circuit
HC- goes to the white ground circuit
D+ goes to a 12 volt hot (only when the truck is running) or if you run you clearance light while traveling you can wire it to the black “clearance marker lights”
If you wire it there the fridge will run off the truck when lights are on and off the trailer if lights are off.
Hope this helps some
All of those wires except an 12volt ignition hot can be found inside the trailer in the 12 volt 7 pin distribution box on late model trailers. Not for sure on a 1970.
Old 06-08-2018, 07:30 AM   #4
GMFL's Avatar
Dadeville , Alabama
If you wired the D+ to the red stop light circuit The refrigerator would run off the trailer battery while going down the road and off the truck battery when the brake pedal was depressed.
The D+ wire is a sensor wire the tell the fridge the TV is present and running to prevent the fridge from running your TV battery dead if off and not unplugged.
Old 06-08-2018, 07:53 AM   #5
GMFL's Avatar
Dadeville , Alabama
Plug tagged
Old 06-08-2018, 08:08 AM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Most, if not all modern TV's have a relay which disconnects the "charge line" when the key is off.
Check to see if this is the case with your TV.
If so D+ can be connected to the charge line along with the + from the TV.
As long as you don't leave the key on for long periods without the engine running you should be OK. IMHO
TG Twinkie is online now   Reply With Quote
Old 06-08-2018, 09:08 AM   #7
1970 25' Caravanner
TomW. Sorry for the low res photo. Here is a link to the PDF
https://www.thetford.com/wp-content/...ler-Wiring.pdf
Old 06-08-2018, 09:16 AM   #8
1970 25' Caravanner
GMFL. So helpful. Thanks so much. My plug is wired as was in 1970 so have to do some checking to see if matches the attached wiring diagram. Hoping it is.
Can you give advice about what gauge wire is needed for each? Have read maybe 8 or 10 AWG.
Old 06-08-2018, 09:37 AM   #9
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Depends on the distance from tv battery, installtion manual should cover it.
Uses 15.8 amps from what I see.
https://www.engineeringtoolbox.com/a...uge-d_730.html
Alan
AlinCal is offline   Reply With Quote
Old 06-08-2018, 10:54 AM   #10
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I used to own a Hi-Lo trailer that had a 3 way fridge. When set to battery the fridge took power exclusively from the trailer battery. While I was driving, the vehicle would send voltage to the battery via the bargeman plug. All worked well until time took its toll on the connection between the trailer plug and the bargeman socket. In many cases I found that I arrived at a campground only to find my battery dead. The main problem was that the Hi-Lo's hydraulic lift system was 12 volt powered. So for all intents we either had to plug the trailer into a 110 volt outlet and wait for sufficient charge to raise the trailer, or I had to unhitch and jump start connect the tow vehicle battery to the trailer battery.
Bottom line I looked at the plug on the trailer and found that the terminal that carried 12 volt power had a very thin layer of green corrosion on the copper blade. That was reducing the voltage available to charge the battery. From that point on I used to used a can of spray electrical contact cleaner and would spray that contact prior to plugging into the tow vehicle receptacle.
Keep in mind that technically you should be able to operate from the trailer battery, provided that your tow vehicle is wired to provide a 12 volt charging circuit and the wire size is adequate to transfer enough power to keep that battery charged. Refrigerators take a lot of amperage in 12 volt mode to operate that heater and in my opinion are really only to be used while a source of power is available to keep that battery charged. Don't try to get charging power from an existing vehicle wire that is serving another electrical function. Typically that 12 volt wire is dedicated for supplying power only and runs from an independent fused position on the vehicle terminal board.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-08-2018, 11:22 AM   #11
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Fill your freezer a day or two before you leave, and stop and buy a bag of ice for the fridge at the start of your journey. 12 volt is a good backup, but hard on batteries. I only have a 2 way, but can keep both the freezer and fridge plenty cold for several hours of travel daily (six hours a day is my limit with a couple of breaks where I do turn the propane on in the fridge).
If I am going to a rally... then I buy the food at or near my destination.
Old 06-08-2018, 11:29 AM   #12
2007 22' International CCD
"red stop light circuit" should be the "red running light circuit" else the fridge would ONLY run when you are braking the rig...this means you should drive with tow vehicle running lights ON, as many of us do anyway...My AS rear and side view cameras are powered this way...
rmkrum is online now   Reply With Quote
Old 06-08-2018, 03:39 PM   #13
2015 19' International
Beaverton , Oregon
N3104
12V/DC 16.2A
120V/AC 1.8A
That's a lot of current. Why can't you use gas for the fridge when travelling?
pg
pgeller is offline   Reply With Quote
Old 06-10-2018, 12:06 AM   #14
1970 25' Caravanner
AlinCal. Thanks for that table, going to have to go lower gauge than had anticpated.
jcanavera. Thanks for the advice. Will add that spray electric contact cleaner to the supply box.
Foiled Again and pgellar. Valid points. Have never had a 3 way and was intending on buying another 2 way but this is the way it ended up. If we have the 3 way, then might as well have use of all of its capabilities. Have the skins partially off as am remodeling so no better time than now to get the wires in place.
Charge AS via ZAMP port by Tow Vehicle? airstreaker Electrical - Systems, Generators, Batteries & Solar 9 07-24-2016 12:45 PM
Charging AGM Batteries via Tow Vehicle Charge Wire gtbzz85 Electrical - Systems, Generators, Batteries & Solar 5 10-06-2012 04:20 PM
HItch ball height via AS and via Leveling mefly2 Hitches, Couplers & Balls 5 03-13-2012 02:56 PM
Rear Camera installation wire thru existing lead via fish tape to trailer front KD2011 Lights - Interior & Exterior 8 03-24-2011 04:31 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 12:09 PM
