Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 06-01-2007, 12:11 PM   #1
asilomardad
Profile:  1973 26' Argosy 26
pacific grove , California
How to start my fridge?
I am ready to check my appliances on my 73 Argosy 26 how do I find out about firing up my fridge? any help would be appreciated. Thanks- Asilomardad
asilomardad is offline   Reply With Quote
Old 06-01-2007, 12:38 PM   #2
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
Do you want to start it on gas or electric?
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 06-02-2007, 10:16 AM   #3
asilomardad
I'd like to know the procedure for both. Thanks for the reply-Asilomardad
Old 06-02-2007, 03:23 PM   #4
erock53
Profile:  1978 31' Sovereign
Cincinnati , Ohio
I also would like to know the procedure. I have a 78 that I'm in the process of restoring and I'm not sure if the fridge works. It has not been used for the past 15 years. Anything that I should look out for. The fridge is so expensive to replace..
erock53 is offline   Reply With Quote
Old 06-02-2007, 03:45 PM   #5
tn2
DixieDove
tn2's Avatar
Profile:  1978 Argosy 27
Camden , Tennessee
refrig
Most important that your unit be level
tn2... Bad thing about doing nothing is you never know when you're done.
tn2 is offline   Reply With Quote
Old 06-02-2007, 03:51 PM   #6
tn2
DixieDove
tn2's Avatar
Camden , Tennessee
Refrig
Most important is that your rig (MH/Trailer) be level. If you operate the frig in an unlevel position for very much time...it causes a coating to accumulate inside the refrigerent pipes. This coating can get so built up that it shuts down the refrig all together. Believe it or not the only thing you can do then is to remove the complete refrig and turn it upside down...this is called burbing. That procedure may or may not fix the problem.If it doesn't fix you have a choice of a new refrig or to install new refrig cooling unit....both expensive.
If you are trying to operate on gas....you first turn on the gas tank supply....then you select knob to gas...then you set thermo to #4 ...pull out on the pilot knob and push in the ignitor knob until it lights.....may take several tries.
In the electric position it will work just like any refrig
Just make sure unit is level
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 08:01 PM
Replacing RM100 fridge....troubles? JohnGalt48 Refrigerators 3 04-18-2004 08:13 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 08:40 AM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 07:34 PM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 07:44 AM
