Old 11-05-2006, 09:11 AM   #1
Auretrvr's Avatar
Iowa City , Iowa
How to remove Dometic reefer trim for painting?
I have lost a wonderful thread in which someone had cleaned and painted trim a Dometic that looked like our '83 (3-way with freezer above). It works fine. I want to use the Alsa mock stainless adhesive sheeting to re-face ours. I think it is too heavy to push the edges under the trim as you might with contact paper, so I need to remove the trim. I see a couple of screws that would remove the plastic logo piece, but don't see how to get the anodized copper-look trim off the doors. While I am at it, I want to paint that black.
Can anyone point me to that thread? Any ideas on what paint to use?
Thanks!
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
Auretrvr is offline   Reply With Quote
Old 11-05-2006, 11:01 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If you are asking how to remove the trim panel from the center of the doors, take the top plastic piece off the top of each door, bow out the trim in the center, and pull up. The trim piece will slide right out.
Charging old Dometic Reefer smily Refrigerators 9 09-18-2017 03:50 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 04:36 AM
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 07:19 PM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 12:04 PM
Exterior trim ALANSD Airstream Motorhome Forums 1 04-14-2002 08:53 PM
