Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 09-07-2007, 03:16 PM   #1
1973 31' Excella 500
oyama , bc
how to get fridge out?
i am trying to remove the fridge from my 73 excella 500 to put in an a/c unit
ive taken all the screws out i can see on both sides ,is it scewed to the floor?
thanks scott
scottyrrr is offline   Reply With Quote
Old 09-07-2007, 03:25 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Generaly there are 2 large screws, one on each side, screwed into the flooring at the rear of the frig.
The front can have lots of small screws around the edges.
2004 Excursion 4x4
Old 09-07-2007, 03:28 PM   #3
oyama , bc
there are none in the back bottom and ilooked along the bottom rail with a mirror and didnt see any screw heads.
Old 09-07-2007, 03:39 PM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Look down under, mate
The refrigerator, in my Overlander, was installed after the belly skin was.
On my Airstream, the belly skin has two rubber plugs directly beneath the refrigerator's floor-bolts to seal the holes the technicians used to install the bolts.
Tom
Old 09-07-2007, 03:41 PM   #5
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
Have you checked out this site?
http://www.snydersrvrefrigeration.com/page6.html
Part of the removal instrunctions indicate that the unit may be siliconed in place.
Royce (K0RKK) 146.460 simplex
Web page https://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 09-07-2007, 04:05 PM   #6
oyama , bc
no silicon on this baby
Old 09-07-2007, 04:07 PM   #7
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Just took mine out of a 79 Argosy and it had a piece of aluminum screwed to the side of the frig. and to the wall, I had to remove the partition to get to it.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 09-07-2007, 04:09 PM   #8
oyama , bc
i think ill have to do that,its just a pain!
thanks
scott
Old 09-07-2007, 04:12 PM   #9
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
A couple years ago, someone on the forum took pictures while replacing their fridge. Anyone remember who it was?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 09-07-2007, 05:37 PM   #10
TomW's Avatar
1967 26' Overlander
Craig,
John HD documented replacing the innards on his fridge. Did he detail the removal in the same thread?
Tom
Old 09-07-2007, 06:48 PM   #11
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
tom
i didn't take any detail shots of the removal as it was straight forward, 2 large screws though the floor in the rear and four on the face of the fridge.
the bottom of mine was siliconed but the sides and top used open cell foam tape.
john
you call them ferrets, i call them weasels.
Old 09-07-2007, 08:25 PM   #12
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Removing the fridge
As opposed to just about every other coach manufacturer in the world which puts in the cabinets first and then bolts the fridge to the floor, Airstream does it backwards on this vintage of coach They put the fridge in position 1st and then build the cabinetry around it. I know this for a fact on my 71 because I have taken it out. The bulkheads and counter tops are screwed into the fridge which holds it in place, but it is not screwed to the floor. This means I had to take out the bulkheads, one cabinet and the counter. Not quite as bad as it sounds.
If you are considering replacing the fridge make sure you can get a replacement that will fit. Neither Dometic or Nor Cold make a model of close size to my original. I would have to go bigger or smaller. There are several people out there that will rebuild the original units.
Old 09-07-2007, 08:48 PM   #13
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 220
Remove the Partition
You've got to remove the partition to the right of the fridge. There's no other way.
You'll find two pieces of aluminum holding it in place...one on the floor and one on the curved wall. There are no other screws unless it's been replaced.
Seems like a pain but there's no other way, trust me....I know!
Here's a picture of it removed in my '73 Sovereign. (Sorry, I didn't take any pics of the old one attached to the wall and floor.)
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 09-07-2007, 09:12 PM   #14
oyama , bc
thanks ill do that
do fit all those kids in that airstream?
i have twin 5 year olds and its seeming small !
Old 09-07-2007, 09:46 PM   #15
tisaacs's Avatar
1965 26' Overlander
Lizton , Indiana
I just finished taking one out. However, I was doing a complete gutting so it was much easier. This is on a 65 Overlander 26' and, as mentioned in prior thread, there is aluminum attached to the back of the frig at the top connected to the wall. Also, there were 4 large bolts that went through the floor. I did take photos, I'll see if I can get them to post... good luck.
-Todd
ID:	44581Click image for larger version
ID:	44582Click image for larger version
tisaacs is offline   Reply With Quote
Old 09-08-2007, 11:02 AM   #16
PizzaChop's Avatar
1973 31' Sovereign
Images: 220
Piece of cake!
Ron Kaes
Psalm 112
www.paparonnis.com
Old 09-08-2007, 11:53 AM   #17
TomW's Avatar
1967 26' Overlander
Strong sense of order
Originally Posted by scottyrrr
... do fit all those kids in that airstream? ...
You ought to see Ron in action at the campground with his kids - That guy can really work well with large groups of people.
Tom
Not using fridge fan Toasty's Dad Refrigerators 1 05-24-2006 10:07 AM
Fridge Devoman Refrigerators 2 11-04-2005 07:00 AM
'67 fridge... JMGAZ Refrigerators 3 07-26-2005 09:03 AM
Fan on fridge ardenrj Refrigerators 12 06-30-2005 07:22 AM
What is 2 way vs 3 way fridge? Astrodokk Refrigerators 12 06-01-2005 03:33 PM
