Old 07-17-2011, 08:05 AM   #1
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
How much flame should there be when running on gas?
I do not have model but should there be a roaring flame or just a little flame?
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 07-17-2011, 08:17 AM   #2
aftermath's Avatar
Spokane , Washington
Are you talking about your water heater.....refrigerator....?
aftermath is offline   Reply With Quote
Old 07-17-2011, 08:19 AM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
It's the fridge. And it's just a little flame, not really any larger than a pilot light on other appliances.
Lynn
WBCCI 21043
Old 07-17-2011, 08:52 AM   #4
2005 19' Safari
GLENDALE , AZ
You won't hear anything like the flame thrower in your hot water heater. After the ticking stops on ours (to start), I can barely hear anything when I'm outside looking directly at the back of the refrigerator. Inside, you can't hear anything.
Old 07-17-2011, 08:55 AM   #5
1973 25' Tradewind
waynesboro , Virginia
On my 73 when the refrigerator is running on gas I am able to hear the slight "popping"
sound of gas ....It is a very low level noise, but it certainly can be heard!
waltero is offline   Reply With Quote
Old 07-17-2011, 09:24 AM   #6
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
When we light ours to propane mode, it will 'PHOOM!' a few times and then a verticle blue flame appears (should only burn in blue. If yellow the feed of propane is too rich and must be adjusted. (good luck with that). The fridge will run on propane for almost a month (at least ours does on one tank full.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 07-18-2011, 02:36 AM   #7
1977 31' Sovereign
Images: 33
Sorry it is the frig
K/N Cool intake air
Duel power exhaust
Old 07-18-2011, 05:47 AM   #8
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Sounds about right to me, just a little larger than the average pilot light. As mentioned above, the flame should be a pretty blue with maybe a small touch of yellow at the very top edge of the flame.
Does the refer get good and cold while on propane?
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 07-18-2011, 08:50 AM   #9
1977 31' Sovereign
Images: 33
Nope this is a rebuilt refridg burnt out heater for electric operation which worked fine till it stopped(hope running during winter did not kill it)Just got gas all up and running on trailer first time for gas the freezer get real cold but refridg is like room temp. Any ideas I'll post model number tonight .
K/N Cool intake air
Duel power exhaust
Old 07-21-2011, 05:28 PM   #10
1977 31' Sovereign
Images: 33
Ok model number is Dometic RM 2652 it is rebuilt fridge
1) worked great first two months installed on electric
2) left plugged in all winter
3) around april uncovered trail opened frig noticed not cold
4) FYI gas not hooked up because replacing bad gas line frig had one bad line.
5) frig was working both freezer and ref before winter
6) hooked up gas switched to auto a click and no light I disconnected gas flow solenoid tapped it a few times connected it and it lit
7) left on over night freezer very cold ref room temp
So replacing heating element should not be issue but why do it if frig is toast any idea on which was to go now?
K/N Cool intake air
Duel power exhaust
Gas Oven to Replace Convection/Microwave 10Smiles Stoves, Ovens & Microwaves 7 08-26-2011 08:52 PM
Cooling problem on gas Pahaska Refrigerators 38 08-22-2011 05:18 PM
Gas on, gas off? heavyjumbo LP Gas, Piping, Tanks & Regulators 28 07-23-2011 07:59 AM
Got gas? ROBERTSUNRUS Off Topic Forum 13 06-25-2011 12:14 AM
