Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 03-29-2006, 08:40 PM   #1
wacnstac
Profile:  1979 31' Excella 500
Detroit Area , Michigan
Images: 41
How long does it take a Dometic to fire up and get cold
Just wondering what is typical when they are run on 110 and propane as far as cool down time.
wacnstac is offline   Reply With Quote
Old 03-29-2006, 08:49 PM   #2
bimi
bimi's Avatar
Profile:
Mine is 35 years old, so I don't know if this is normal or not. But, it normally takes mine about 1 whole day to really get good and cold on either the propane or the electric. I always get it going the day before I leave so that I can put my food in there when we go and it will stay cold while we are traveling.
Again, though, mine is really old. I am planning on putting one of those little fans in there, though. That is supposed to help it cool down quicker.
bimi is offline   Reply With Quote
Old 03-29-2006, 08:59 PM   #3
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
8-12 hours is average.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 03-30-2006, 05:10 AM   #4
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
all over , Fulltiming
Images: 58
Mine is nearlv brand-new, so it works a little faster. You can feel the freezer getting cold after an hour or so, it gets cold enough to put food in after about 6 hours, and reaches its set tempurature after about 8 hours. Most folks will light off the fridge on LP, since it generally cools faster on LP, and when it gets cold, change over to electric.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 03-30-2006, 05:46 AM   #5
Chaplain Kent
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
I have a 25 year old three way and it takes about 10 hours to cool completely on electric, a little shorter on propane. I plan to keep this wonderful fridge until my children inherit Chummy.
Does anyone use those little fans that are supposed to cool down the fridge quicker? I do but I doubt it works.
Chaplain Kent
1982 280 Turbo Diesel Motor Home (Chummy)
http://www.fuzzytravel.com/grandakent/
Chaplain Kent is offline   Reply With Quote
Old 03-30-2006, 07:42 AM   #6
DocBear
DocBear's Avatar
Profile:  Milwaukee , Wisconsin
I'd say about 75% of what I've been reading about the fans say they don't work. A friend with a Roadtrek and a fan in his unit says he wasted his money, but YMMV.
DocBear is offline   Reply With Quote
Old 03-30-2006, 09:04 AM   #7
Mike Lewis
Profile:  2006 30' Classic
Farmington , New Mexico
Images: 14
Docbear---I put a fan in an 05 classic we owned and had good results. The purpose however was not to reduce the time needed for cool down but to help the unit get colder in hot weather. We used our when we were in 90 plus temps ,particularly when the sun was beating on the fridge side of the trailer. The cooler you can keep the area behind the fridge the more effecient it will operate. The smallest of fans that will help move air through that area are beneficial. I used a manual switch to turn ours on as needed but a temperature controled one could be used.----Pieman
Mike Lewis is offline   Reply With Quote
Old 03-30-2006, 12:26 PM   #8
DocBear
DocBear's Avatar
Good to know, Mike. Thanks.
It's a simple thing to add, so I can't see where it would be a "bad" thing to try out.
Old 03-30-2006, 04:35 PM   #9
norbert
norbert's Avatar
Profile:  1993 30' Excella
chicagoland , state of confusion+north of cheddar curtain
Images: 24
there is a thread on this mod....high heat high humdidity conditions warrant it....
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 03-30-2006, 08:12 PM   #10
lewster
Commercial Vendor
lewster's Avatar
My 19CCD came from the factory with a cooling fan on the fridge coils. Plus, I have found them (double fans in fact) on every large Norcold unit that I have worked on. The purpose is to keep cooler air moving across the condenser coils so the refrigerant can transfer the heat out of the freezer more efficiently.
AIR # 10325
