Old 05-22-2019, 09:18 AM   #1
2016 23' Flying Cloud
Fanwood , New Jersey
How level does it have to be to operate fridge?
Our 2016FC23D is parked on our property on a slight hill with nose up. When the jack is lowered all the way down, we can make the trailer almost level but not completely level. It is almost imperceptible but with instrument, we can detect nose being slightly elevated still.
I'm wondering if I can operate the fridge in this condition. It doesn't have to work really well as long as we can get it to somewhat cooler the night before a trip.
If I turn it on, it's not going to blow up, is it?
Atsushi is offline   Reply With Quote
Old 05-22-2019, 09:28 AM   #2
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
Not sure, but probably OK. Is it possible to park your trailer heading the opposite direction? That way you should be able to make it level, I would think.
Hiho Silver is offline   Reply With Quote
Old 05-22-2019, 09:29 AM   #3
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
If it's anywhere close to level it will work. We've been in spots where we couldn't get level and it still worked. The situation you described won't be a problem.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 05-22-2019, 09:35 AM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
My manual says:
"Leveling is one of the requirements for proper operation with
absorption refrigerators. To ensure proper leveling the vehicle
needs to be leveled only so it is comfortable to live in (no noticeable
sloping of floor or walls)."
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-22-2019, 09:35 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
With a modern fridge, if you can "live" in the trailer, it's level enough. If you feel awkward walking around in the trailer, it may not be level enough.
Old 05-22-2019, 09:53 AM   #6
2013 20' Flying Cloud
Westerly , Rhode Island
No, it will either work or not. Probably will.
smithcreek is offline   Reply With Quote
Old 05-22-2019, 10:12 AM   #7
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
We recently camped in a very unlevel site and my best effort to get situated was still way off. It was an epic location at Kirk creek on big sur coast and no other sites available so we made do. Fridge was a concern but worked fine, the shower drain not so good.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 05-22-2019, 10:18 AM   #8
2012 19' International
Southeastern MI , Michigan
Mine won’t cool if it’s more than a half bubble off.
2018 International Serenity 27' FB
Michelin 16Ē tires
Hensley Arrow hitch
Tow Vehicle: Ram Laramie 2500 crew cab, Cummins 6.7 Turbodiesel
Countryboy59 is offline   Reply With Quote
Old 05-22-2019, 06:13 PM   #9
Long Island , New York
What does your owner's manual say?
Old 05-22-2019, 09:05 PM   #10
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
...you want it to last.....level...the bubble is 90% in the circle...I have never had to replace one..since 1971...
Old 05-23-2019, 10:02 AM   #11
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
It's the same in any TT with an absorbent type Refrig - make it as level as human possible.
La Dolce Vita Brick & Mona
2004 International 25CCD "Blue Streak"
2013 F-150 SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
drbrick is offline   Reply With Quote
Old 05-23-2019, 10:11 AM   #12
2016 19' Flying Cloud
Newtown , Connecticut
AS a side note, I've read it's okay to have the fridge operational when underway to keep food from spoiling when travelling from one destination to another. Given the ups and downs of highway surfaces, will this varying degree of levelness pose a significant problem?
brundom is offline   Reply With Quote
Old 05-23-2019, 10:17 AM   #13
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Plus or minus 5 degrees will work fine........
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 05-23-2019, 10:20 AM   #14
2007 22' International CCD
No, not usually because the motion helps circulate the fluids in the system by sloshing them around. The problem is when itís far out of level and sitting still. Bubbles stop the liquids from circulating properly, hot spots occur, and then the problems start.
Most modern absorption units work fine when leveled properly fore and aft in the trailer assuming the fridge is mounted against the outer wall like normally done. Leveling the other way is not as critical. If yo can walk comfortably and sleep with your head up slightly (I have a crosswise bed) itís good enough.
My criteria is if DW is not complaining about being out of level, itís close enough. A degree or so wonít matter. I try to get the head of the bed, on the street side, higher than the foot for comfort. Fore and aft leveling is easy to get precise with the tongue jack and then stabilizers to prevent rocking. I use a level on the floor near the fridge to check it.
How does the AS warranty operate John1048 Dollars & Cents 12 04-16-2018 08:56 AM
No kidding. How level is level? upnorththree Towing, Tow Vehicles & Hitches 19 03-25-2017 01:14 AM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
How does this valve even operate? OregonArgy Waste Systems, Tanks & Totes 5 04-12-2008 09:29 PM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
