Old 02-10-2014, 03:24 PM   #1
1969 31' Sovereign
catlett , Virginia
How do you remove a frig from a 1969 31 foot Sovereign International land Yacth
I am fixing up my 1969 31 foot Sovereign International Land Yatch. The original frig needs to be replaced. How do you remove the frig?
shorty1 is offline   Reply With Quote
Old 02-10-2014, 04:15 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
It is screwed into the cabinet with 4 screws, perhaps behind some trim pieces, 2 top, 2 bottom, we think. Memory is hazy...it was 6 years ago. It did fit out the door, but is HEAVY, so need probably 2 strongish people.
Kay
Old 02-12-2014, 09:27 AM   #3
m.nolte's Avatar
1967 30' Sovereign
Fairhope , Alabama
On our '67 it was screwed to the floor, to the underside of the countertop and then to the wooden panel between it and the oven with the head of the screw against the oven. We had to rotate that last one out with a set of pliers.
Melissa
m.nolte is offline   Reply With Quote
Old 02-20-2014, 08:39 AM   #4
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
Removing the Dometic Fridge from a '77 31-footer...
My Dometic was screwed into the side bulkheads with 3 or 4 screws per side and 2 screws into the floor at the rear of the fridge - access these screws from the outside access panel. Takes only about 15-20 minutes to remove it.
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Old 02-20-2014, 09:06 AM   #5
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
My 75 you had to remove the side bulkhead, AC thermostat.
Then it had metal straps hooked to the frame of the trailer. also counter
top over food cabinette had to come off, more metal straps. Slid it out to door
on plywood over the floor..but repaired it. If going for a new one watch width.
These old ones are 22 inch, new I think is 24.
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Old 02-20-2014, 09:19 AM   #6
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
My 69 had 2 bolts going threw the floor. You should have two holes in the belly pan where you can access the nuts.
There will also be rivets and screws that are located in the fridge side walls attached to the fridge under the sink. And finally two angle pieces of Alclad. One on either side of the top of the fridge connected (rivet)to the fridge and screwed to the shelf above the fridge. These can be reused for the new fridge.
Sent from my LG-E617G using Airstream Forums mobile app
Cyquest is offline   Reply With Quote
Old 03-03-2014, 11:55 AM   #7
airstream66's Avatar
1966 30' Sovereign
Bethany , Illinois
Images: 22
I just removed my fridge in my 66 sovereign. It was more difficult than I expected. There were 2 long screws underneath on the right side that looked to be anchored through the floor into the frame. I had to remove the wood panel on the side to get to them. Also had to remove the oven and remove numerous screws and a few rivets on the left side. After disconnecting the gas line and unplugging the 110 plug, there were shims taped to the bottom of each bottom side rail. Once they were removed, it came out ok.
Cory, Angie, and 'Lucy'
1966 Sovereign International
2003 Black Chevy Silverado w/q-steer
airstream66 is offline   Reply With Quote
Old 03-03-2014, 12:54 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Does anyone beside me think that trailers are put together in such a manner to promote the notion that any kind of maintenance or repair is best handled by the dealer?
sovereign
jcbarrbelr :: 1966 Airstream International Sovereign jcbarrbelr Airstream Registry Discussions 0 12-12-2011 01:53 PM
1985 Triple Axle 35 foot Airstream Sovereign Trailer with two awnings! eBay Watch Airstreams on eBay 0 11-08-2011 08:00 PM
1969 Airstream Sovereign meta4matt Airstream Registry Discussions 0 09-27-2011 09:42 PM
1984 Airstream International 34 foot, 3 axle Travel Trailer eBay Watch Airstreams on eBay 0 09-26-2011 08:20 PM
1969 Airstream overlander International ClayC Airstream Registry Discussions 0 09-19-2011 03:16 PM
