Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 05-25-2006, 11:01 PM   #1
1965 24' Tradewind
lakewood , California
How do you get the fridge out???
I have a 65 Tradewind. I can't figure out how to get the fridge removed. Is is bolted on the bottom? and the sides or what? It's hard to see the bottom because of the shell underneath the trailer. . .
mickfly is offline   Reply With Quote
Old 05-25-2006, 11:18 PM   #2
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Pictures would help.
Mine is screwed through the bottom "runners" to the floor, and through the side from the adjoining cabinet. You will have to remove the wood panel on the end to access the bottom screws.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 05-25-2006, 11:22 PM   #3
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
It's a bugger!
We had to remove ours out of our '64 GT a couple of seasons ago. I'm sure each model varies a bit based on size, location & interior configuration. But we had four bolts through the floor that could only be accessed through the vent in the belly pan under the trailer. It would have been better if our arms had extra joints to bend the way they needed to! These bolts attached the bottom support runner of the fridge securely to the floor. There wasn't anything else as I recall, but we struggled with just those four #@!*&% bolts for the better part of a day...definately a two person job. One to hold the bolt on top the other to loosen it from below.
I know I've heard and read of some that you have to disassemble a credenza or part of the kitchen cabinets to get to some bolts as well.
Hopefully someone with the same trailer can help out with more specifics...in the meantime, take a look below to see it this helps.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 05-26-2006, 04:06 AM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
If it is anything like the mid 70's there is a plate on the floor and wall that screws to both.
This pic kinda gives you the idea.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 06-14-2006, 10:56 PM   #5
1965 24' Tradewind
I got the fridge out!!!
"I finally got the thing out. There were four bolts on the bottom but it was screwed in from the closet. The screws were covered nicely with wood dowels countersunk into the wood. Hard to find!!! Good craftsmanship."
Replacing RM100 fridge....troubles? JohnGalt48 Refrigerators 3 04-18-2004 07:13 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
RV Ideas to consider ??? FrankR General Repair Forum 18 09-18-2002 10:43 PM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 06:34 PM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 06:44 AM
