Old 07-27-2010, 12:46 PM   #15
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
Sounds like you have it operating quite well. Isn't it a relief when the suspense is over and a plan pays off?
I think we would all benefit from photos of the installation.
Sam
samb is offline   Reply With Quote
Old 07-29-2010, 08:10 AM   #16
1962 24' Tradewind
Berry Creek , California
Exhaust pipe, cooling fans and venting pictures
These images show:
1) the exhaust pipe for the propane burner (I found a nicely-bent steel pipe from an old swing-set that worked perfectly) to vent out between the ribs. Everything is sealed with heat-resistant fireplace caulk, but the pipe will just pull out of the hole if I pull the fridge out.
2) the indoor supply vent as well as the access door open (the indoor supply vent is necessary when traveling or when the access door is shut).
3) the cooling fans above the condenser (4, 80mm computer fans). I will hook the fans up to a thermostat to control when they turn on and off.
In the photo looking down the back of the fridge (showing the pipe), you can also see the aluminum baffle, a sheet of aluminum that makes a solid, straight wall up against the back of the refrigerator. Prior to doing this, I believe there was too much dead air space in the curved part of the trailer behind the refrigerator and that contributed to my original overheating problem, too.
Now I just need to finish off the open hole with some kind of perforated metal grating, louver or vent material... well, and paint the walls, and fix the skylights and fix the windows and polish the outside and.... you know.
ID:	107717   Click image for larger version
nmeyer is offline   Reply With Quote
Fixed Pilot- Fridge wont cool - PLS HELP!! Elf1 Refrigerators 6 06-26-2009 10:30 PM
- 26 Degrees | Everything is fine nunya001 Winter Living 32 05-03-2009 10:13 PM
Frig at 72 degrees, needs to be level ??? wagnerda Refrigerators 18 01-20-2008 04:00 PM
Sweet 16 (degrees) and all's (mostly) well Antique Pedaler Our Community 1 03-04-2007 08:56 PM
Dometic fridge not so cool kenajen Refrigerators 15 03-30-2006 05:05 AM
