Old 02-09-2012, 10:38 AM   #1
musicmaster's Avatar
1976 31' Sovereign
Greenwood , South Carolina
House or RV Fridge
I'm in the rebuild stage of a full monty. Shell is back on, wiring in and interior skins back in. I'm trying to decide on a fridge for it, so I'll know the size. I have been searching for comparisons of RV units and it seems that a lot of folks are putting in a house type unit. If you have any suggestions on either kind, please let me know.
musicmaster is offline   Reply With Quote
Old 02-09-2012, 10:48 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
For all the work you're putting into this, in my opinion it makes no sense to put in a household fridge. The latter would impose penalties related to weight, travel style, camping options and resale. Maybe a rationale exists if you were planning on parking this and not using it for travel.
5 meter Langford Nahanni
Old 02-09-2012, 01:17 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A household refrigerator will probably require a dedicated 110v 20-amp circuit. No 12v option, no propane-fired either. That means you'd be stuck with a large current draw from an inverter if you weren't hooked into shore power 24/7.
Cats and ultraleather Airstream upholstery don't mix!
Old 02-09-2012, 01:34 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
120v fridge will work although there have been some sporadic reports of them failing early due to vibration from people who put a lot of miles on their RVs. Obviously they will only work when there is 120 volt power. The smaller fridges do not require a dedicated outlet and don't draw much power but they do draw enough that a typical inverter installation can't support one.
You might also consider the 12v refrigerators sold mainly for the marine market:
Products - Dometic
Network Solutions E-Commerce Web Site - CR Series Built-In AC/DC Refrigerators with Flush Flange
Old 02-09-2012, 01:52 PM   #5
Maniacal Engineer
barts's Avatar
Menlo Park , California
For really custom solutions, long distance sailers will build their own heavily insulated refrigerators and power them w/ Danfoss 12V compressors which are very efficient - usable w/ solar, for example.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 02-09-2012, 04:21 PM   #6
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Seems like the question is simply "Do you intend to travel in your trailer, or to leave it permanently parked?" If it is never going to move, and will always be wired up to a 110 power source, then a conventional 110 only fridge would work, and would be the cheapest option. If you intend to actually travel in the trailer, then it seems the RV style fridge would be the default choice, not only because of these fridges' ability to use gas or electric, but also their durability (shock, vibration, etc).
If you intend to travel, but always expect to be staying at an RV park with full hookups, then I would still recommend the RV style fridge, so that it can run off of propane while on the road to keep the contents cool. Any fridge you use will require cool down time of many hours. Many RVers will power up their fridge a good 12 hours before getting on the road and put their perishables in as the last step before leaving. If you are considering trying to use a 110 only fridge for travel, I would suggest you would be as well off with a cooler and ice.
Old 02-09-2012, 05:23 PM   #7
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
A Lot of Folks...?
Originally Posted by musicmaster View Post
... it seems that a lot of folks are putting in a house type unit. If you have any suggestions on either kind, please let me know.
I've been pulling a travel trailer of one kind or another for almost 40 years. I don't recall seeing more than a couple household fridges in any TT used for camping or even travelling from one RV park to another.
Both instances I remember were Airstreamers who making do with a small, dorm-size fridge until they could replace their Dometic.
I've seen full-size, household refers in those rundown travel trailers that have become permanent residences, all too common here in NM.
Is your lovingly refurbished Airstream to be a travel trailer or a fixed-mobile residence? The answer should guide your decision how to equip it.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 02-09-2012, 05:58 PM   #8
Very good post!
In spite of intent to camp with hookups only, please note that most national parks and the great majority of national forest campgrounds will not have electric supplied to campsites.
Old 02-09-2012, 06:05 PM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Amen. When we first started we mostly wanted to camp with hookups...now it seems we dry camp more often than we have hookups and don't even think about it! Being set up to dry camp and boon dock opens up whole new camping opportunities to enjoy.
TB & Greg and Abbey Schnauzer
#3954
Old 02-09-2012, 06:18 PM   #10
1981 31' Excella II
New Market , Alabama
What I have seen in trailers for sale is they do a cheap and dirty rebuild and put a house fridge in just to say it has one. When you only have 30A it runs out pretty fast when you start running everything on 120V. I run mine on gas when traveling. If it is never going to go anywhere again then a 120V fridge is the way to go. If it is a camper forsale I would see a 120V only fridge as a negative. What other short cuts have they made besides the fridge.
Perry
Old 02-09-2012, 07:22 PM   #11
Mexray's Avatar
1978 28' Ambassador
Morada , California
It seems there's an increasing number of Diesel Pusher Moho's that are specifying 110 VAC only refrigerators as their standard installation...
These rigs not only have a diesel generator, but also have large HD type inverters and additional batteries installed to run the frig while on the road...the rig's high output alternator on the power unit can supply plenty of 'charging power' to keep the inverter's batteries topped off when running down the interstate...
Of course, most of these big rigs also only park where there's AC electricity available, so no problem running the frig...
This kind of installation of a large inverter, large battery bank, on board generator just aren't options easily fit into an AS TT - duh...we all know that, right?
Good old propane (and natural gas) refrigerators have been in use forever, and actually operate quite economically - back in the 50's we had one at home as our only frig and it was an old 'sucker' then!
It's really too bad the RV frig's cost so dear, as in reality they are quite a simple design - modern mfg's like to add all kinds on 'bells & whistles' to make them more complicated to operate - better mouse trap, and all that, to justify the large initial purchase price, IMHO...
Ray & Pat; Morada, CA
Old 02-09-2012, 08:56 PM   #12
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Musicmaster,
If you’ve spent any amount of time on these forums you’ll know that you need to consider the difference between opinion and experience when shifting through the advice.
Many of the opinions given here so far are based on bias and conventional thinking and many of the points offered –about weight, resale, power draw, el cheapo renos, etc. – are just conjecture or plain wrong.
Whether you can use a 110 v. fridge depends mostly on how you plan to use the trailer. If you’re going to be mainly in the boonies then 110v is probably not so workable. I think you already knew that when you posted.
I opted for a small, very light, 8.6 cubic foot LG household fridge for my remodel. I’ve used it for 5 years without a hint of a problem.
The idea was put into my head by Andy Thompson, the long time Airstream dealer at London, Ontario, when he opined that a household fridge like this is a perfect size for trailer living and could easily be powered by a 1500 watt inverter.
His said it was well built but lighter than an RV fridge and cost 75% less. It could be repaired anywhere by pretty much anyone – no tricky LP or 12v systems. You could actually throw it out and get a new one if it ever broke down.
The fridge normally operates on shore power but when I am going overland for any serious amount of time, or dry-camped overnight, it operates perfectly off of my battery pack.
Sergei
See my main thread here:
http://www.airforums.com/forums/f227/contemporizing-1976-argosy-d-opinions-please-18448.html#post182701
SmokelessJoe is offline   Reply With Quote
Old 02-09-2012, 09:31 PM   #13
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Lot's of good points in the above posts. We had a dorm fridge the first year with our TW. When I finished the refurb,I installed a Dometic and the wife and I both feel like it was worth every penny. Having the option of not needing a hookup, keeping food cold while traveling and having a place to put food at home in case of long term power outage (tornado, hurricane, etc) made the extra cost worth it. A tank of propane will keep your food cold a lot longer than a can of gas for a generator needed to run a 120V only fridge.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 02-10-2012, 09:48 AM   #14
1976 31' Sovereign
Thanks for all of your input, it is exactly what I am looking for. I have camped several times before in another trailer, yet I have never needed to use the gas for the fridge. I kept the trailer plugged in and turned it on a couple of days before we left. I am in the process of doing a remodel, but as you can tell from the photo it is not one of those "JUST REMODELED" jobs. It is also not a cost issue, the house fridge I had looked at was about 1200.00. I just seem to hear about more problems with the RV fridges. Home models tend to have more room as well. Of course I am a fairly new camper and just have not stayed at too many different places yet. I thought most campgrounds had power, but again I am still fairly new to camping.
It might explain a lot if I tell you my other trailer is a enclosed car hauler with sleeping quarters. I used it for car audio shows and competitions related to my business. I quite often stayed at civic center or speedway parking lots, but I always ran off of the generator or invertor. My car hauler dose have a much better battery bank as well. Thanks Mexray for that insight, it had not crossed my mind about the batts.
I was on Moho sights looking for RV fridge comparisons, that is where the "lots of folks" comment came from. Lots of them said they went back with a house fridge when their RV fridge went out.
Thanks again and keep them coming,
Splastro
Old 02-10-2012, 10:49 AM   #15
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Lots of good posts here, and I pretty much agree with all of them.
The only thing that I might add is that rv fridges seem to have a hard time keeping cold when the outside temperature is real high. To help with this, and no matter what type of fridge you install, I would install some additional insulation around the fridge so that it will cool better in hot weather and also use less energy to keep cool (ie less propane or less battery).
Dan
Old 02-10-2012, 11:08 AM   #16
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Good points
Originally Posted by SmokelessJoe View Post
Musicmaster,
Attachment 150663
Attachment 150664
Sergei
I'm also in the middle of a rebuild and had considered another fridge so that we would have more capacity. Sergie, that LG that you have looks nice a testament to it's durability is the amount of time you have had it and it still works well. I think you do put some miles on your trailer. Unfortunately I think you might have a hard time replacing as I did not find that it is still readily available.
SilverHoot is offline   Reply With Quote
Old 02-10-2012, 11:51 AM   #17
1968 28' Ambassador
Dover , Arkansas
fridge
I've got a Fridgedaire in mine, so far its working good in my 68 Ambassador. But, It'sonlymy first time out with the trailer. I live in it full time for 6months out of the year, with full hook ups, so thats not a problem for me. Its only a couple months old, so can't say how long its going to last. I've had 2 fridges go out in my house in 2 years. And it sits still. Go figure. Guess it depends on how you'll be using your trailer for you though.
Eagleuh1 is offline   Reply With Quote
Old 02-10-2012, 03:53 PM   #18
Wise Elder
Jammer's Avatar
2010 30' Classic
While it is rare that we spend the night at a location without electricity, we do make stops during the day while traveling and it is in this situation where we most often depend on the propane fridge. Our fridge cools well and so there's no stress about the food if we stop for errands or coffee or sightseeing or whatever in the course of a journey.
Sergei's setup is unusual in many regards and his success with a household fridge is due in large measure to an unusually large and well designed battery and inverter system.
Old 02-10-2012, 04:05 PM   #19
1976 Argosy 24
SilverHoot,
Appliances, AC plants, etc. seem built to have a 15 to 20 year useful life so I won't need to worry about replacement unless I'm unlucky and it breaks down.
This currently available LG is bigger than mine, 10.6 cubic feet, but the exact same weight - 69 pounds - and dimensions.
Refrigerators | LG GR-349R Bottom Freezer Refrigerator | LG Electronics Canada
Old 02-10-2012, 05:48 PM   #20
1976 Argosy 24
Jammer,
I think all the colour photos make my outfit look more exotic than it is.
My battery set up is pretty much the standard stuff that many other owners have: a couple of AGM’s and a charger/converter. The inverter is just an everyday Canadian Tire (like AutoZone in your country) model.
I guess the real reason that I got a regular fridge is that I don’t have propane. Why pay for the extra fanciness?
I’m just saying that people who want to consider the household fridge option shouldn’t be deterred by the traditionalist naysayers and the misinformation about stuff like weight and current draw or the attitudes about cheapening or ruining a trailer experience.
I think the household fridge option has attractions like serviceability, contemporary styling, size, weight and price among others.
A quick search on Amazon shows an equivalent to my fridge is $700 so my set up is less than half the cost of the standard RV way. Most of the other fridges listed are under $500, so, with inverter, that’s a quarter the cost.
I installed my set up for a practical reason rather that to save money but this comparison shows another legitimate reason to ask if you must have a 3-way fridge.
Unless one is primarily a boondocker, going household is a valid option that can also give more style, size and performance for less money.
Plugging into the inverter is basically the same as turning on the gas.
Sergei
Clipper, Dometic Refrigerator, Fridge Lamp Switch masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 10 01-05-2013 12:14 PM
Fridge Sorta Kinda Works perryg114 Refrigerators 17 10-23-2011 08:46 PM
'69 Overlander Fridge: RM 2500 gas electric edglenn Refrigerators 1 09-07-2011 11:09 AM
New fridge on the Outs? skydiva Refrigerators 2 07-04-2011 04:04 PM
Skip the Fridge? (Overlander Newbie) pyrenees Refrigerators 15 05-09-2011 06:30 PM
