Old 05-16-2010, 10:36 PM   #1
1983 34' Excella
Cloudcroft , New Mexico
Wink hot wire dometic heating element
My doemetic refrigerator wont start on Gas OR Electric. But when I hotwire the AC heater element the fridge works fine. The problem with this is that heater element stays on all the time. I need to wire a thermostat between the AC power and the element. Anyone have any thoughts on this
johnfarrow is offline   Reply With Quote
Old 05-17-2010, 06:36 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I would say you probably need a new circuit board. If you can have it tested, and find out it's the culprit, replacement of it might be a lot easier than wiring in a thermostat to try and control 110 VAC based on the interior temp of the fridge.
Chris
Old 05-18-2010, 06:14 PM   #3
1983 34' Excella
Was the thermostat
I shorted out the leads from the thermostat control and it worked ok. Now, can I install the thermostat without removing the fridge? Where can one be purchased?
Heating element in Dometic fridge Ultradog Refrigerators 7 03-11-2015 12:49 PM
heating element insulation flyingscot Refrigerators 3 10-01-2008 02:54 PM
Refrigerator Heating Element Badco8 Refrigerators 4 11-20-2007 11:57 PM
Oven heating element, Caravel ncsuzy Stoves, Ovens & Microwaves 6 04-28-2005 05:03 AM
Suburban Heating Element Fallman Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-29-2004 07:13 AM
