04-05-2013, 11:03 AM
Airstream fanatic
Bouse
help!!! No Power on one side of trailer!
Yesterday, the power in the town I am in went out. The entire right side of my 79 Sovereign has no power whatsoever... the plug ins, the fridge, nothing. I have a Domestic RM100 My food is going to go bad if I don't do something!!! How can I make my fridge/freezer turn back on??? I followed the instructions in my manual and I put knob A on electric and turned knob G to 4, checked and rechecked the attachment plug on the back of the fridge, and hooked up a new cord on the back because the original one stopped working....
I've also flipped the breaker many times and unplugged the main electrical plug outside and plugged it back in... my plug-ins don't work either. The whole right side of my trailer is dead!!!
Help!
04-05-2013, 11:06 AM
Normal
Have you checked fuses?
Maggie
04-05-2013, 11:07 AM
Belington
, West Virginia
Check your fuses.
04-05-2013, 11:13 AM
Airstream fanatic
Bouse
Where is the fuses at???
04-05-2013, 11:16 AM
1966 24' Tradewind
Placerville
You should have automotive type fuses near the battery box or nearby.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
04-05-2013, 11:17 AM
Alamo Heights
Run the Dometic on gas for now. Then you have time to figure out the issue with your 120V system.
So when you're plugged into the shore power receptacle at your campsite, you have 120V power from the receptacles down one side of your trailer but not the other? If you've cycled the breakers in the trailer (all of them, not just the main) with no effect, it may be that you (or an electrician, if you're not completely comfortable with this) need to replace a breaker and/or tighten the connections in the 120V panel in your trailer.
— David
04-05-2013, 11:19 AM
Airstream fanatic
Bouse
Okay I will try that. What fuse is it?
Alamo Heights
re: the references to automotive fuses: Isn't an RM100 just a bigger version of my RM75 and doesn't have a 12v connection, just 120v and propane? Knowing where the 12v fuses are is a good thing, certainly, but if the fridge doesn't use 12v and the 120v receptacles are dead it won't help with the problem at hand.
— David
04-05-2013, 11:28 AM
Airstream fanatic
Bouse
The plug works and it has power. For some reason the fridge/freezer won't turn on. It is a 120v. I just don't know why its not working if the cord has power and I've followed all the steps in the manual.
04-05-2013, 11:39 AM
Uxbridge
, Ontario
try plugging a light into the fridge plug to make sure its the fridge and not the plug... if plug that temp wire an extension cord to fridge to see if fridge starts
04-05-2013, 11:48 AM
Alamo Heights
OK, initially you reported that the entire side of your trailer is dead and hadn't said anything different up to now. Or are you saying the shore-power plug works and has power but half the trailer is still dead? As already suggested, plug a lamp in where the refrigerator plugs in and make sure as a troubleshooting step.
The RM100 is both electric and propane (assuming your propane system is working, of course.) Either way, it's VERY slow to respond even when everything is working properly, if it had time to warm up while the power was out it may take a while for you to tell that it's operating. The first place you'd notice it would be the bottom of the freezer starting to feel cold. I'm partial to propane operation because I can see the flame (in the little sight-glass prism on the left of the row of controls.)
It has an electric heating element above where the gas burner is (accessible from the outside locker behind the refrigerator.) When the refrigerator is working, either that heating element will be warm/hot or the gas flame will be on. A way to test the electric operation would be to have a meter like a Kill-a-watt inline to see if there's a current draw from the heating element.
— David
04-05-2013, 11:57 AM
Airstream fanatic
Bouse
I have an extension cord that has power plugged into the back of the fridge.
04-05-2013, 12:07 PM
Airstream fanatic
Bouse
The propane has not worked since we got the trailer. The electric worked just fine until yesterday. The heating element was warm earlier, but it is no longer warm. The I do not have anything to plug into the fridge cord.
04-05-2013, 12:13 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Quick check of other possible causes…
1 - Is the refrigerator level? Not the trailer, the fridge itself. If it's not level, circulation in the cooling system won't work right.
2 - Is it fully charged with ammonia? If it's leaking, you'll probably see a yellowish powder somewhere on the tubing, close to where it's leaking.
3 - Is the venting unblocked? A blocked vent will prevent the unit from cooling.
04-15-2013, 01:22 PM
Airstream fanatic
Bouse
I got the fridge to work, but the plug ins in the living room and in the kitchen don't work... everything else does. What can I do?
04-15-2013, 01:59 PM
1974 Argosy 26
Morrill
, Nebraska
Check all of the circuit breakers in the 120 volt panel. Turn them completely OFF and then back ON.
With the circuit breakers off and NO power to the trailer ( unplug it) check for lose connections at the circuit breakers and the neutral buss (where the white wires connect) as well.
Look at all the outlets. Perhaps a PO installed a GFIC and it is tripped. I don't believe this coach came with GFIC breakers. But there may be a chance that someone installed one and it has tripped.
Good luck
