Old 06-30-2009, 08:52 PM   #1
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Help fridge problem
I just stopped for the night and either myself of the kids left the fridge door not latched and it was on the floor of the trailer.
Now it won't turn back on....
Will it reset it self and start working Or am I screwed...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-30-2009, 09:01 PM   #2
Shut the reefer off.
Leave it off for at least one full day.
With the reefer still off, tow the trailer about 20 to 25 miles, making many stops as well as turning several corners.
Then when you get back home, I assume your home now, let the trailer rest for a half day or so.
Then fire up the reefer. It should now cool properly.
If it still refuses to cool, then it bit the bullet.
Sometimes, we pay dearly for some of our tiny mistakes, especially when we reach that "senior" plateau.
Good luck with the attempt to revive the departed reefer cooling.
Old 06-30-2009, 09:04 PM   #3
You might also make sure the burner and oriface is very clean, as well as the reefer flue.
I would suggest you do that before the other approaches to restoring the cooling.
Old 06-30-2009, 09:06 PM   #4
purman's Avatar
1968 28' Ambassador
I'm on the road, and none of the lights will light up.... Even though I have 12 volt and 110...
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-30-2009, 09:11 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
If the refer panel lights are all off, check the 12 volt fuses.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 06-30-2009, 09:16 PM   #6
purman's Avatar
1968 28' Ambassador
Good call moosetags, My main 12volt wire I had reatached to the board had come off.
Sweet the fringe works again..
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Guide to troubleshoot your fridge problem Cristina1966 Refrigerators 4 07-03-2017 08:52 PM
domestic fridge problem nightowlhooter1 Refrigerators 7 05-11-2016 10:25 AM
dometic fridge problem nightowlhooter1 Refrigerators 27 08-19-2006 05:06 PM
New Member-Baja info-Vintage propane fridge problem dover2019 Member Introductions 3 12-21-2005 11:38 PM
Fridge problem solved Don in E Texas Refrigerators 3 10-14-2005 12:48 PM
