Old 07-03-2008, 07:50 AM   #1
sigv's Avatar
1963 24' Tradewind
Pittsford , New York
Help - Dometic what does the check light mean - on the road with no manual!
At our campsite and our Dometic fridge (model RM2551) check light is on. What does that mean?
We have gas and we have batteries.
I do not have the manual handy - can anyone help?
Much thanks in advance!
-Sig
sigv is offline   Reply With Quote
Old 07-03-2008, 08:50 AM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
It usually means it was running on gas and for one reason or another the flame went out. Turn the unit off for about a minute and then turn it back on. That resets everything and it will try to run on whatever is available, electric or gas. Make sure the "AUTO / GAS" button is in the AUTO position.
If you ran out of gas, it may take a couple of off/on resets to get the gas back to the ignitor.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 07-03-2008, 10:06 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
As above. If that was just working on gas did you just change the gas bottles? Sometimes air will get in the line while changing tanks and when that air hits the burner the ref. goes off.
Was the ref. working on gas just before this happened or has it been off for a while at home? If it has been sitting for a while you may have a spiders nest in the burner tube. First see if it will work on electricity. If yes remove the burner tube and check it for a nest.
2004 Excursion 4x4
Old 07-03-2008, 10:18 AM   #4
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
I would check level also...
don't ask how I know...
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 07-03-2008, 11:00 AM   #5
HowieE's Avatar
Images: 12
Bill
Well Bill since you brought that up did you ever have to ROLL your ref?
Yes some of the older ones if the flame is good and the electric works but the box still does not get cold they have to be rolled. Remove the ref. and turn it over side to side at least 3 times. I have never had to do this but I know several that did have to.
Theory is the ammonia crystallizes in the return tubes and blocks the flow.
2004 Excursion 4x4
Old 07-03-2008, 11:29 AM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Roll the Refer
For a time I worked for a rental houseboat outfit in the Sacramento River Delta. They had 104 houseboats. It was not uncommon for a boat to come back in with the refer not working. They were all propane only. In most cases the boat had been anchored against a levee and when the tide went out, became stranded at quite an angle, then the refer quit, and not get cold again. In those cases we would pull the refer out and give it a good "roll", including turning it up-side-down, replace it and it would again work just fine.
Don't know the physics involved.
Old 07-03-2008, 02:26 PM   #7
1 Rivet Short
1989 25' Excella
yep...done that...it is usually a temporary fix for a unit on its last leg
Old 07-08-2008, 02:15 PM   #8
sigv's Avatar
1963 24' Tradewind
That worked
Turning it on / off did the trick. Guess I just had to reboot the fridge! - thanks!
Old 07-08-2008, 02:57 PM   #9
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Kind'a like my co-pilot re-boots me..
just turn me upside down a couple times and I'm good for another year.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 07-08-2008, 04:48 PM   #10
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Let us know when the next annual "Bob Toss" will be, I'd like to get pictures for my blackmail files...
check light, dometic, fridge
Hitting the road check list smallfry On The Road... 8 12-12-2016 12:52 PM
Light or light cover over the door.. help please! harestream Lights - Interior & Exterior 19 08-29-2008 09:51 AM
Scare light and marker light won't work??? shinybean Lights - Interior & Exterior 12 02-12-2007 08:51 PM
Refrigerator "Check" light on mcostanzo Refrigerators 5 06-27-2003 10:06 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
