Old 06-21-2014, 08:38 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Heating element for 1964 Dometic
Hi all,
My fridge fires (out of the trailer) on propane. I took it to a local Amish place that works on propane appliances, and they cleaned everything and got it running like a cold winter on propane. I think it set me back about $20. The thing hadn't run in 30 years.
It does not get cold on electric. I suspect the electric heating element. Any ideas on what part # I may need to replace this? I see plenty of sources for Dometic heating elements online, but I wonder if these would work in such an old fridge?
Thanks for any direction the membership can offer.
Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 06-21-2014, 09:17 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
All you need is the wattage of the old element.
Don't get a higher wattage unit thinking it will do a better job. The refer is designed for the specific wattage.
Pull out the old element. It will probably be stamped on the end with the wattage rating.
Check the physical dimension of the new one as compared to your old one. They need to be close to fit.
Heating element in Dometic fridge Ultradog Refrigerators 7 03-11-2015 12:49 PM
hot wire dometic heating element johnfarrow Refrigerators 2 05-18-2010 06:14 PM
Oven heating element, Caravel ncsuzy Stoves, Ovens & Microwaves 6 04-28-2005 05:03 AM
Suburban Heating Element Fallman Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-29-2004 07:13 AM
Source for Heating Element foe Norcold 624 srgntpepper Refrigerators 2 05-11-2004 05:02 PM
