hello
I need the dimensions of the heater element that is in the RM 67
fridge
here in the netherlands we have 220 volts I ques that if I put 220 volts on the fridge it wont last long
I have found a suplier over here for heating elements
but they need all the dimensions of the original element
and how it is mounted
I don't like to take the original out before I have the replacement
I have a transformator but wat to use it for the A/C only
so that I am able to use two power outlets on a campground
here most campground have 6 amps 220 volt 1350 Watt
only to low for A/c Fridge and convertor on one outlet
Remco
Try emailing one of the outfits like RV Mobile. They should have one they can measure. I looked at the site quickly and didn't see any drawings, but it did have Dometic part #173709007 for the RM67, that might also help.
