Old 07-17-2011, 09:59 PM   #1
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Having problems with Dometic Refrigerator
Please Help me!I can't get my Dometic refer to fire up on propane or electric.I have power to the outlet that it's plugged into.It is level foward aft but off a little bit side to side.Does it have to be perfectly level?
I don't know what else to try.I did try to lit it from the outside that's why you'll notice the black marks.
Please ignore the silver bullet.
desertair27 is offline   Reply With Quote
Old 07-17-2011, 10:55 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I'm not a refer expert but I can tell you that the leveling issue for RV refrigerators is for the ammonia heat-exchange system, not for whether or not the burner will light, so slightly imperfect leveling shouldn't keep it from lighting off.
— David
Old 07-17-2011, 11:43 PM   #3
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Do you have your travel rocker switch in the correct position? I had fits with mine once and several days later realized I had the switch in the "store" position which defeats all systems.
Phrunes is offline   Reply With Quote
Old 07-18-2011, 08:07 AM   #4
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I'm not aware of that switch.Can you tell me what and where it could be?
Old 07-18-2011, 05:57 PM   #5
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Some refers (not all) have a small 3 way rocker switch that allows you to select run, store and ? Mine is on the face of the unit between the fridge and freezer doors. Look all around the front top to bottom for a switch that is about 1/2" x 3/4". Hope this is your solution. Good luck!
Old 07-18-2011, 06:51 PM   #6
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Thanks, I'll be search for that magic switch asap!Appreciate the tip!
Old 07-18-2011, 07:13 PM   #7
x
XXXX , XXXX
What model fridge is it?
wasagachris is offline   Reply With Quote
Old 07-18-2011, 08:11 PM   #8
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I believe it's a RM100 if I remember right. Appreciate your help.
Old 07-18-2011, 08:21 PM   #9
x
XXXX , XXXX
I have a copy of a service manual I can send you. I tried to e-mail it to you but you do not have that option set up.
If you PM me your e-mail I will send it to you.
Old 07-18-2011, 08:34 PM   #10
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Thanks so much for help. I pm you with my info. I hope I did it correctly. I'll work on my email option.
Old 07-19-2011, 05:33 AM   #11
1972 23' Safari
raleigh , North Carolina
Attachment 135171
Attachment 135172
Looks like someone is drinking on the job! Mine frig is on the blink too. Seems from what you say, you are getting juice, but no heat in the 'chimney' and no gas at all. You have to have heat on the ammonia for it to work. trace the gas line to see that it is not cut off somewhere. Check the "on" switch in the front for the electricity, and that it is switched to "on." Don't know how you would get two 'switch' problems at once, but you seem to have that.
djofraleigh is offline   Reply With Quote
Old 07-20-2011, 03:17 PM   #12
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I've got GAS!!!
I recieved the service manual.Thank you very much.Armed with new information I was able to attack the refer and determine that I was not getting gas.The gas valve control at the refer was not opening.ONce I figured that out she fired right up.Now to give it a few hours to see if it cools down.It is to good to be true?Time will tell.Then it's on to the electrical side of the refer.Keeping my fingers crossed.
What a great sight.
Old 07-20-2011, 04:27 PM   #13
x
XXXX , XXXX
Glad I could help. Give the fridge at least four to six hours to get cold. It may take even longer in the Texas heat. BTW you can take the Texas heat back any time you like. It's 90 F here right now and the expected low tonight is 84F with the high peaking tomorrow at 97F.
Old 07-21-2011, 01:34 AM   #14
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
no rocker switch but refer is working.
No luck on the switch on my model but I was able to figure out that the refer wasn't getting gas.After 6 hours the freezer is working but the refer is barely cool.I'll see how it is working tomorrow.
Thanks for the help.
Question: Can you keep the refrigerator on while towing? Scott J-24 Refrigerators 59 11-25-2015 08:53 PM
Mystery Refrigerator Problem Solved moosetags Refrigerators 14 07-19-2011 12:15 PM
Parting our Dometic RM 75D refer. buffaloman Refrigerators 0 07-07-2011 09:35 PM
Screw length for side of refrigerator AirHome Refrigerators 2 06-04-2011 08:39 PM
3 refrigerator installation questions Lothlorian Refrigerators 16 03-06-2011 09:40 AM
