Old 01-12-2019, 07:46 AM   #1
2018 27' Globetrotter
Bolivar , OH
Globetrotter Refrigerator issue
After 100 nights, discovered some issues with refrigerator. The internal drain line does not extend outside but to a small plastic container which allows for evaporation, like a house refrigerator.
My problem, in Florida that evaporation cannot be counted on and when I turned up temp on fridge because of ice inside, the system became overwhelmed and flooded rear compartment.
The rear compartment is only partially sealed. As photos show, there is a half-hearted attempt by factory to seal up rear fridge compartment but caulking is missing in several areas and absent in others. There are also 3 deep gouges in compartment floor which might also leak.
For me, solution will be to extend drain tube through fridge rear compartment door as is commonly done by some manufacturers and to finish job of properly sealing compartment.
ID:	331516   Click image for larger version
ID:	331518   Click image for larger version
Samstu is offline   Reply With Quote
Old 01-12-2019, 07:57 AM   #2
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
The reason they seal the compartment is To keep carbon monoxide out of the cabin and same for a possible propane leak
I have our drain piped to the edge of the access door
AlinCal is offline   Reply With Quote
Old 01-12-2019, 08:58 AM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
When we are using the refrigerator for a long period we find that it is necessary to defrost the unit. I turn it off and use a hair dryer to help dislodge the ice from the cooling fins. These refrigerators do not auto defrost like a household unit.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 01-12-2019, 03:04 PM   #4
AirUSN's Avatar
2013 25' FB Eddie Bauer
Bonita Springs , Florida
I just defrosted mine today, back to the days of growing up without a frost free refrigerator!!
'13 Eddie Bauer 25'
'19 Ram Crew 4x4 Limited
Realtor w/Keller Williams, Fort Myers, Naples area and beyond, SL3388777
AirUSN is offline   Reply With Quote
Old 04-06-2019, 07:08 PM   #5
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
If you put a fan inside your refrigerator you will not have a problem with frost building up inside. I have not had to defrost my fridge in 2 years and it runs all the time.
ID:	337483   Click image for larger version
ID:	337485   Click image for larger version
Dept of “OverKill”
GMFL is online now   Reply With Quote
Old 04-06-2019, 07:36 PM   #6
dznf0g's Avatar
Oswego , Illinois
https://www.rvcoolingunit.com/Dometi...-P3239952.aspx
I prefer this fan, just because of the bulk of the above unit.
-Rich-
Old 04-06-2019, 07:37 PM   #7
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Ok, now I have to ask, "How do you power that thing from inside the fridge, and where can I get one?"
Also: I get the worst frost up in the freezer section. Is there a cure for that, aside from turning the unit off and defrosting it?
Rocinante is our 2014 International Signature 27FB
Old 04-06-2019, 07:52 PM   #8
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Haha. I built mine myself using a piece of 2x3 aluminum tube, a couple end caps, two small (20mm) fans, a switch, and a 3 amp DC breaker. It is powered by 12 volt. The (+)Pos lead runs through the drain hose and connects to the power behind the fridge. The (-)Neg lead is connected to the inside cooling fins by one of there mounting screws. The fins are grounded.
You can by one at
https://smartrvproducts.com/
My understanding is if you fix the fridge frost problem that the freezer will not be a problem...
Dept of “OverKill”
Refrigerator AC Issue Joe Oertel Refrigerators 2 05-04-2016 07:10 PM
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Refrigerator issue RickJacobs13 Refrigerators 5 10-21-2015 09:12 PM
Refrigerator issue.. won't run when switched to LP ? Focusfactor1 General Repair Forum 6 07-25-2013 09:18 AM
1976 Argosy 24' - Dometic Refrigerator issue NAM_FL Refrigerators 1 05-21-2013 10:51 AM
