Old 03-16-2016, 03:00 PM   #1
1978 25' Caravanner
Toledo , Ohio
Gas Thermostat Dometice RM66E
I need a source for a propane thermostat for a Dometic RM66e Refrigerator. The electric still works fine.
If you know of a source for old parts, I would like to hear from you.
Richard
RichB is offline   Reply With Quote
Old 03-16-2016, 03:27 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Are you sure the thermostat is the problem? What are the symptoms?
I have had success finding parts for refers on eBay.
Old 03-16-2016, 03:55 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
The thermostat is connected to the control board and controls both electric and gas. If electric works I doubt it is the stat.
Does the gas light at all when set to gas? You may have to remove the panel around the burner to see if there is a flame.
2004 Excursion 4x4
Old 03-16-2016, 07:23 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I don't believe a refer of the 70's generation has a control board.
Can you post a pic?
Old 03-22-2016, 03:48 PM   #5
1978 25' Caravanner
Toledo , Ohio
Thanks for the questions and suggestions. The thermostat was changed in October, and worked thru November, and then began to freeze up. (I changed it because it did not cool.) Airstream and I have checked it, and the thermostat is not changing the flame. Light it, and it is on. Down to between 10 and 20 degrees Fahrenheit. So it is toast.
The RM66E is an old model. The Land yacht was built in 1978. The electric and gas thermostats are separate. It works on electric, which means the refrigerator is still good (kind of a miracle). but, not on gas.
I would like to have another thermostat. I have found one, which is described as an "after market." I am hoping it will work, but we will see.
Old 08-02-2016, 03:41 PM   #6
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
A real "thermostat," like the electric thermostat, varies the cooling effect in response to temperature inside the fridge. Temp goes up, electric heaitng element comes on, fridge cools down.
The gas "thermostat" is actually just a vatiable flow gas valve. It's up to you to figure out if you need a higher or lower flame.
WTB Dometic gas thermostat w/ capillary tube obscure1 Airstream Classifieds 0 06-27-2014 06:32 PM
Need a gas thermostat for RM-60 pickerdd Refrigerators 5 07-24-2010 10:23 PM
Thermostat Gas Heater - Digital Donk Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-20-2010 04:48 AM
Water heater thermostat does not shut off gas to burner davelance01 Water Heaters, Filters & Pumps 2 06-12-2009 09:55 AM
Locking Gas Cap for 2003 AS Gas Motorhome spat61 Land Yacht/Legacy Motorhomes 11 10-27-2008 11:37 AM
