Old 10-10-2011, 02:41 PM   #1
ELKAY12
1974 25' Tradewind
1993 25' Excella
Rocky Mount , North Carolina
Gas fridge
can you run you fridge on propane when your towing it /
elkay12 is offline   Reply With Quote
Old 10-10-2011, 02:57 PM   #2
JFScheck's Avatar
Rockville , Maryland
Images: 33
Yes, I do all the time as do many others. There are two thoughts to this, I find it fine as the propane valve will not run if the burner goes out, some are worried that in an accident the propane will stream out of the busted hose if ruptered....
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 10-10-2011, 02:58 PM   #3
Absolutely, as long as it's functioning ok. No leaks, etc.
Clipper, Dometic Refrigerator, Fridge Lamp Switch masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 10 01-05-2013 11:14 AM
1967 fridge gets cold on 110V, but not on gas aircooled4 Refrigerators 15 10-26-2011 07:58 PM
'69 Overlander Fridge: RM 2500 gas electric edglenn Refrigerators 1 09-07-2011 10:09 AM
Fridge not working with Gas, still works w/electric Tim_S Refrigerators 3 09-02-2011 05:06 AM
