Old 03-23-2006, 11:47 PM   #1
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Funny thing with the frig
I had to cut my propane line to the frig to splice in a catalytic heater. When I tried to restart the frig, it took forever and would not light. I had propane to the heater which was within 2 feet of the frig connection but, it would not light. Removed the wind screen and there was a carbon buildup on the igniter that had bridged to the thermocouple and was grounding the spark thru the carbon. This is the 2nd time something like this has happened. Alway when propane has run out, etc. Has anyone had a similar experience? Why am I getting the carbon buildup. Is this an early sign of problems to come? It is an old frig but, works good. Perplexed?
wingfoot321 is offline   Reply With Quote
Old 03-23-2006, 11:54 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
If the fridge was turned on, but the gas turned off, then the ignitor will try and light the fridge flame every few seconds. Eventually this will cause a carbon "bridge" type thingie by the ignitor. Game over.
This is providing that your fridge is of the semi-automatic variety.
Uwe
www.area63productions.com
Old 03-24-2006, 06:29 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Uwe is correct!
If your fridge is in the 'on position' and there is no 120VAC to it, it will automatically think that it is to be running on propane and will try to ignite with the spark. It will do this until it ignites and senses the flame from the burner or you turn on the 120 VAC or you turn it off.
Old 03-24-2006, 10:11 AM   #4
1990 32' Excella
jonesboro , Arkansas
failure to light
I had that problem and my pressure was to low leaving the regulator.I put a pressure gauge in the line between the end of the line and the fridge.I then adjusted my line pressure to 11.5 to 12 psi.On your regulator there is a screw to turn and moove your pressure up or down.If you have air in your line going to the heater it ca cause your fridge to be slow to light also. Good luck.
joel is offline   Reply With Quote
frig and a/c suggestions Neenm General Appliance Topics 6 04-08-2007 08:42 PM
Pilot light in Frig niftypkg Refrigerators 9 04-10-2005 01:04 PM
The Real Thing 4521red Our Community 5 01-05-2003 01:01 PM
Frig replacement.... Silver Bullet Refrigerators 1 12-19-2002 11:10 PM
Rust on Frig. niftypkg Refrigerators 0 05-20-2002 07:43 PM
