A bad board after less than 3 years. Is that normal?
Michael
I have seen them bad right out of the box. There is a tester that they plug the board into that will tell you if it is bad or not, a decent RV repair center should have one. For some reason the Dometic OEM control boards are basically junk, you would think they would make them better but I guess it is cheaper to just say "oops" and install a new board under warranty rather than put a decent one in to begin with....
Aaron
WBCCI #2449 AIR #2495
I don't know guys, this past September coming home from Yellowstone we stopped at JC to have our frig serviced. After a week on the road it became a freezer. It was actually funny; I woke one morning, started the coffee, took the eggs out and went to crack one and I couldn't. Turns out it was frozen solid! Along with a whole bunch of other stuff. Well we did fine turning it on during the day and off at night. I put a temp guage in it to help regulate the temp. When we got to JC the first thing they did was replace the board. Did not solve the problem. Next a new sensor, that was it. Seems that the sensors go before the boards. If this is any help!
__________________ J. Rick Cipot Sandi Gould NEUNew England Unit Airstream Life Magazine WBCCI #3411 AIR #17099
If you're handy with money (yeah, right!), you could replace both parts. Or, if it isn't a special order, you could replace the sensor first (should be cheaper) and if it works, you are in business.
Terry Change is inevitable, except from a vending machine
AIR#2611
Follow-up to 3 year old, the poorly performing Domatic 2820.
Without replacing any parts, and reinstalling the temp probe to its original place...
1. I selected a quarter round piece of firewood (mesquite) in the classic size for a piece of firewood.
2. Turned fridge OFF and let the coils cool to ambient temp.
3. Grasping firmly, I inserted both my arm and the firewood up into the outside fridge compartment and proceeded (with gusto) to beating about the coils and pipe above the flue (without causing and dents mind you) for a full 90 seconds.
4. THE RESULTS:
The fridge works as it was when new. I have delayed reporting for 3 weeks.
At burning man, with temps in the high 90's the fridge held a temp of 34 degrees at setting 3.
For the past 3 weeks it has held this temp with temps in the 90's.
Said fridge has both an internal fans and a thermostatic controlled vent fan.
I would like to thank Lewester for all his expert help
4. THE RESULTS:
So the fridge responed to purcussive repair. I like that.
Royce (K0RKK) and Karen AIR# 3913
