Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 11-11-2003, 10:42 PM   #1
FireFighter's Avatar
bay city , Michigan
Frozen Milk??
Last weekend we did a little cold weather camping, now the weather man said that it was supposed to be in the thirty's but it got to 12 hey kinda close. any way the furnace did a great job heating the tt however almost everything was frozen in the fridge. i turned it way down but still frozen. looking for suggestions. Also i need advice on where to purchase a new water heater, somebody no fingers here was waiting to winterize until after the weekend did i mention that it was 12 degrees. not sure why but my water heater leaks very badly now.
FireFighter is offline   Reply With Quote
Old 11-11-2003, 11:18 PM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Sorry
firefighter
Sorry to hear about your water heater..
May I suggest that you check out Camping World, for your replacement..Expect to spend close to 300$, give or take. Depends on brand, size and, if you install it yourself..etc
When you get around to installing the new unit, now would be the perfect time to also install the bypass kit (they're cheap)for easy winterizin the water heater and, look into a drain cock~
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 11-11-2003, 11:28 PM   #3
bay city , Michigan
thanks for the direction
ohh I will be doing a little replumbing in the tt there is no way to isolate the Hot water heater. what is the kit you spoke about, i am planning on using valving and such for isolation is there a better way?
Any thoughts on the fridge? stuff foam insulation some where???
Old 11-12-2003, 04:04 AM   #4
1984 29' Sovereign
Savannah , Missouri
Thumbs up bypass kit.
firefighter water heater bypass kit
check the image on the upper right hand side..
I don't know what to say about your refrig..But, for some reason..the idea of packing more foam doesn't seem to be the proper solution. I've no doubt but, there's someone on this forum who has had this problem before..Good luck.
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 11-12-2003, 05:14 AM   #5
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
Send a message via AIM to thenewkid64 Send a message via Yahoo to thenewkid64
If your fridge has a standing pilot the only way to prevent it from freezing food when the ambient temp is that low is to turn it off.
Try www.rvcatalog.com for the water heater. I have bough two there and they have the best prices and freight is normally free.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
frozen stabilizer jacks silver suz Jacks, Stabilizers, Lifting and Leveling 10 03-24-2004 10:12 PM
frozen black water dump valve Rick Alston Waste Systems, Tanks & Totes 6 10-28-2003 01:17 PM
frozen pipes kooblekidz Airstream Motorhome Forums 4 01-20-2003 10:56 AM
Contents of holding tank frozen. Dave Emmerich Airstream Motorhome Forums 10 01-12-2003 07:31 PM
Got Milk? Edie Our Community 10 10-13-2002 05:19 PM
