Old 09-11-2008, 10:11 PM   #1
1980 20' Caravelle
Coeur d alene , Idaho
Frost on Freezer Door?
My 1980 Caravell has a Norcold 774 EG2 in it and is staying cold. I am concerned that when I open the frig door the small freezer door has a small build up of frost on it! Is that normal? If the frig needs work I would like to do it during these long Winters Idaho days instead of the nice sunny Summer months! Thanks, Don
glacierrunne is offline   Reply With Quote
Old 09-11-2008, 10:41 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Do you have a manual for the frig? If so, you might look to see if that issue is addressed. Another thing you could do is contact the manufacturer to see what they say.
It could be that the seal for the freezer is not sealing well and letting colder air out into the main refrigerator compartment. Try cleaning the seal (with mild soapy water) and lubricating it with a vinyl or rubber treatment to see if that helps (being sure to wide it clean after treatment so you don't have any residual.
The other thing that might be happening is simply due to humidity in the air... ans the cooler surface of the freeze compartment is freezing that humidity to form frost...if that's what's happening, it's probably a seasonal thing.
TB & Greg and Abbey Schnauzer
#3954
Fridge is a freezer! Help Regele1 2002 - 2005 International 3 07-27-2008 12:29 AM
Freezer is frosting up SaabLover Refrigerators 12 08-01-2007 02:15 PM
Portable Freezer? chaimemet Refrigerators 1 05-06-2007 07:34 AM
Moldy freezer seal 63air Refrigerators 2 03-22-2007 09:57 PM
Temps in the Freezer/Frig??? tenrsingr Refrigerators 38 05-31-2002 03:34 PM
